[blockMesh] Mesh conversion from Star CCM+ to OpenFOAM
Old   July 20, 2021, 09:08
Default Mesh conversion from Star CCM+ to OpenFOAM
murchana
mbbb is on a distinguished road
Hello. I would like to know how to convert a .sim file generated in star ccm+ (having a 3d mesh as well as boundary conditions set) into a OpenFOAM readable file. I am a complete beginer in OpemFOAM as well as Star ccm+.
Basically i would like to know how to convert a 3d mesh generated in star ccm+ to OpemFOAM.
mbbb is offline   Reply With Quote
Old   July 21, 2021, 09:45
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
You need to export as a .ccm file (normally a .ccmg - for geometry) and then use a convertor such as ccmToFoam (in the www.openfoam.com version), for which you need access to the proprietary libccmio library.
Or you can possibly export your geometry as "proSTAR" format, in which case you can use the star4ToFoam utility.
olesen is offline   Reply With Quote
Old   June 8, 2022, 04:45
Osman Veysel Özdemir
ovozdemir is on a distinguished road
I m new on OpenFOAM, I prepared a mesh in STAR CCM+ and I am trying to export it to OF. I searched about it and find this ccm26ToFoam. So now I am trying to use it but getting same error. Can anyone help me?
Details:
OpenFOAM-9 is installed on my ubuntu.
My mesh is tetrahedral with prism layer from STAR CCM+.
I can export it as .ccm format.
ccm26ToFoam doesn't work. (There may be an issue about my installation but I did some analysis before without any problem by using rhoSimpleFoam.)
ovozdemir is offline   Reply With Quote
Old   June 8, 2022, 07:46
Mark Olesen
Attempt to export as a proSTAR mesh (if possible) and use star4ToFoam. Alternatively, there are a variety of ccmToFoam, foamToCcm etc tools in the www.openfoam.com version (ie, from OpenCFD Ltd, not from OpenFOAM Foundation Ltd), but these will still require that you have access to the base-level libccmio library (proprietary).
Old   June 8, 2022, 08:07
Thank you for your response,
I was using an OpenFOAM version from OpenFOAM Foundation, I will switch to ESI groups version. But I couldn't understand how can I install libccmio.
Old   November 22, 2023, 08:47
Default ccmtofoam
Tunc
tuncm18 is on a distinguished road
You can follow this thread:
[OpenFOAM-v1706] ccmToFoam error
tuncm18 is offline   Reply With Quote
Old   January 30, 2024, 08:06
Default mesh conversion is not working
nzacfd is on a distinguished road
Hello olesen, I'm newbie in openfoam, I just installed the openfoam 2306, and tried to used my starccm+ mesh file .ccm, but the problem is:
ccmToFoam -help
ccmToFoam: command not found
how i want to fix this?, thanks so much.
nzacfd is offline   Reply With Quote
.sim, openfoam mesh, star ccm+ mesh
[Salome] mesh conversion Salome --> OpenFoam vaina74 OpenFOAM Meshing & Mesh Conversion 42 March 4, 2022 21:41
[Commercial meshers] Mesh conversion .gtm to OpenFOAM ansab OpenFOAM Meshing & Mesh Conversion 2 December 6, 2016 14:48
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[Commercial meshers] Problems with ANSYS mesh conversion tdog OpenFOAM Meshing & Mesh Conversion 1 March 31, 2016 18:36
