[Other] Gmsh/netgen OF workflow from step file to volumetric mesh
Old   July 19, 2021, 04:45
Default Gmsh/netgen OF workflow from step file to volumetric mesh
Franco
otaolafr is on a distinguished road
I am looking for some guidance with gmsh/netgen,
I am having trouble meshing my geometry with snappy so I though give it a try to gmsh/netgen for creating a tet mesh that would be later converted to a polyhedral with polyDualMesh utility.
I commonly use salome as my workbench for preparing my surface for snappy (separation of patchs and surface meshing). eventhought salome integrates netgen and gmsh inside it, the issue is that it does not support multithreading meshing.
so, I would like to find some guidance if some folks are working directly with netgen or gmsh code (python scripts could do the work, not necessary GUI...) where we import an step file, create the patches in the surface and then create a volume mesh of it. for example for a simple cylinder with an inlet/outlet and walls as patches.
otaolafr is offline   Reply With Quote
gmsh, netgenmesh
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
