[snappyHexMesh] Add layers at the bottom of a mesh |
June 1, 2021, 12:31 |
Clarisse Hayoun
Rep Power: 5 |
Hello everyone,
I have troubles to add extra cell layers at the bottom of my mesh like Scott A.Brown (2016) did in his PhD. I want to add 6 cell layers at the bottom of my mesh, each layer being twice thicker than the layer below it. The smallest one at the bottom should be 1mm thick. Using tutorials, forum posts and youtube videos, I end up with those parameters to add the layers. Code:
addLayersControls { layers { bottom { nSurfaceLayers 6; } } relativeSizes false; expansionRatio 2.0; firstLayerThickness 1e-3; minThickness 5e-1; nGrow 2; // Advanced settings // Static analysis of starting mesh featureAngle 130; layerTerminationAngle -180; maxFaceThicknessRatio 0.5; // Patch displacement nSmoothSurfaceNormals 3; nSmoothThickness 10; // Medial axis analysis minMedialAxisAngle 90; maxThicknessToMedialRatio 0.3; nSmoothNormals 3; // Mesh shrinking slipFeatureAngle 30; nRelaxIter 5; nBufferCellsNoExtrude 0; nLayerIter 50; } Looking at the polyMesh directory and its set sub-directory, the files « addedCells » and « layerFaces » are empty but the other files « nonAlignFaces », « nonOrthoFaces », « skewFaces » and « wrongFaces » are not. I have been struggling for months with it, using documentation, forum and even youtube videos to help me but I am obviously missing something important here. Any help would be more than welcome ! Please find attached my case, run it with the Allrun script attached. Best regards, Clarisse Hayoun p { margin-bottom: 0.25cm; line-height: 115%; background: transparent } |
June 2, 2021, 02:46 |
M
Rep Power: 13 |
You might missed there is a switch at the top of the snappyHexMeshDict. You have to enable addLayers there for snappy to perform that phase of meshing.
I hope it's just that, can't see any obvious error in the rest there. |
June 2, 2021, 05:13 |
#3 | |
Clarisse Hayoun
Rep Power: 5 |
Thank you for your reply AtoHM. I did run it with the switch on, in the dict that I shared with you it might not be on as I tried the other steps before hand to be sure you could run it fully. Best, Clarisse |
June 2, 2021, 05:58 |
M
Rep Power: 13 |
Ok, I checked the case just now.
You reference a region called "frontBack" in the layers-subdictionary. But this name is not declared anywhere in the geometry-section, so it is just ignored. |
June 2, 2021, 06:22 |
#5 | |
Clarisse Hayoun
Rep Power: 5 |
The patch "frontBack" belongs to the blockMeshDict. How do I put this in the geometry-section of snappy? |
June 2, 2021, 12:35 |
M
Rep Power: 13 |
Oh that seems right. Unfortunately, I never used it that way and I found someone else had a similar issue unanswered: Why doesn't SnappyHexMesh retain patches from BlockMesh
Maybe someone else knows how to add layers to a patch from blockMesh? |
[snappyHexMesh] Boundary layers across rotorDisk cellZone | vLhomme | OpenFOAM Meshing & Mesh Conversion | 3 | April 7, 2021 05:46 |
[snappyHexMesh] Snappy add layers failed | mqsim | OpenFOAM Meshing & Mesh Conversion | 1 | January 24, 2021 16:02 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 17:45 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
