[blockMesh] What is $posY and why it is defined in edgeGrading? |
May 18, 2021, 14:05 |
FOAMraj
Rep Power: 5 |
What are $posY, $negY, and $posYR, and why they are defined in edgeGrading? Can anyone explain this geometrically? I extracted this code from this link. https://bit.ly/3v0uhCf
Thank you. /*--------------------------------*- C++ -*----------------------------------*\ |
May 18, 2021, 15:12 |
Mark Olesen
Rep Power: 40 |
The OpenFOAM dictionary syntax supports variable substitution, somewhat like you might have seen with shell script.
- look within the file to see where the variables are defined. - it will look very ugly for the blockMeshDict but don't forget that you can always use "foamDictionary -expand" to see what the final form (after substitution) looks like. |
May 23, 2021, 09:48 |
#3 | |
FOAMraj
Rep Power: 5 |
I am just a beginner in OpenFoam and what I have understood is they are just variables that store the coordinates. One question: What will be the form in line 78(say) if I didn't write it? Will there be errors or any change in the mesh? Thank you. |
mesh and grid, turbulence |
