[snappyHexMesh] keyword allowFreeStandingZoneFaces is undefined in dictionary
Old   May 3, 2021, 07:26
Default keyword allowFreeStandingZoneFaces is undefined in dictionary
Maxime Cabrol
Maxime_Cabrol is on a distinguished road
Hi everyone, when I try to use snappyHexMesh on my imported STL file it seems to work well :
Overall mesh bounding box  : (-1 0 -1) (1 1 1)
Relative tolerance         : 1e-06
Absolute matching distance : 3e-06
Reading refinement surfaces.
Read refinement surfaces in = 0.01 s
Reading refinement shells.
Refinement level 2 for all cells inside cylinder.stl
Read refinement shells in = 0.01 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0 s
Reading features.
Read edgeMesh cylinder.eMesh
    edges       : 880
    boundingBox : (-20 -19.9938 -50) (51 19.9938 50)
Refinement level according to distance to "cylinder.eMesh" (880 points, 880 edges).
    level 1 for all cells within 0 metre.
Read features in = 0 s
Determining initial surface intersections
Edge intersection testing:
    Number of edges             : 192500
    Number of edges to retest   : 192500
    Number of intersected edges : 0
Calculated surface intersections in = 1.12 s
Initial mesh : cells:62500  faces:192500  points:67626
Cells per refinement level:
    0	62500
Adding patches for surface regions
Patch Type                Region
cylinder:
4     wall                cylinder
Added patches in = 0.01 s
Selecting decompositionMethod none
But then I receive this error message :
FOAM FATAL IO ERROR:
keyword allowFreeStandingZoneFaces is undefined in dictionary "/home/maxime/postGeo/system/snappyHexMeshDict.castellatedMeshControls"
file: /home/maxime/postGeo/system/snappyHexMeshDict.castellatedMeshControls from line 52 to line 148.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 566.
I previously successfully applied blockMesh and surfaceFeatureExtract that gave me :
The blockMeshDict I'm using is :
convertToMeters 1;	//This gives you the scale: 0.001 would mean all units in this file are [mm]
vertices		//list of vertices defining the geometry
    (-1 0 -1)		//This is point 0. Not 1!
    (1 0 -1)		//This is point 1
    (1 1 -1)		//point 2
    (-1 1 -1)		//point 3
    (-1 0 1)		//point 4
    (1 0 1)		//point 5
    (1 1 1) 	//point 6
    (-1 1 1)		//point 7
    /* . .. . . . . . . . . . . . . . . . . . . . . On ajoute une surface au centre du cube servant de "inlet" */
    (-1 -1 0.1)		// i1 		—	point 8
    (-1 -1 0.2)		// i2 		— 		.. 9
    (-1 -0.9 0.2) 	// i3 		—		.. 10
    (-1 -0.9 0.1)		// i4 		—		..	11
    				Sortie du fluide
    (1 0 0.99)			// s5			—	point 12
    (1 1 0.99)			// s6			—		.. 13
blocks			//defining the block which the geometry is made out of
    hex (0 1 2 3 4 5 6 7) (50 25 50) simpleGrading (1 1 1)
boundary
    walls	//choose a name for the boundary
        type wall;	//define the type of the boundary
        faces
            (0 4 5 1)	// face 1	—	haut
            (3 7 6 2)	// face 2	—	bas
    inlet
        type patch;
        faces
            (0 4 7 3)	// face 3	—	gauche
    outlet
	type patch;
	faces
            (2 1 5 6)	// face 4	—	droite
    frontAndBack
        type wall;
        faces
            (1 2 3 0)	// face 5	—	avant
            (7 6 5 4)	// face 6	—	arriθre
Thanks in advance.
Maxime_Cabrol is offline   Reply With Quote
freestandingzonefaces, import, snappyhexmesh, stl
LEMOS InflowGenerator r_gordon OpenFOAM Running, Solving & CFD 103 December 18, 2018 01:58
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
