[Salome] How to create Volume group from STL file of assembly |
April 28, 2021, 18:07 |
TL
Rep Power: 5 |
I have created STL file of simple assembly of a outer cylindrical shell and an inner core in Blender 3D software. Then I imported it into Salome. Salome seems not be able to recognize there are two objects. I tried to build solid from the STL file. But it can only generate the outer shell. Then I could not create volume groups for the inner core. Anyone knows how? Thank you. Regards, Tryphena Last edited by Tryphena; April 29, 2021 at 07:01. Reason: Need upload another picture |
June 23, 2024, 07:18 |
Gaurav Gupta
Rep Power: 2 |
Hii, Did you figure out this issue ? I have a similar issue with the meshing in salome. I have a more complex geometry than a cylinder.
volume groups; stl file |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
