[blockMesh] Circumferential refinement mesh on the outside of a concentric cylinder geometry
Old   April 23, 2021, 01:26
Default Circumferential refinement mesh on the outside of a concentric cylinder geometry
Jiaui Zhang
charryzzz is on a distinguished road
Hi Foamer!
I have a question regarding generating a mesh in which different blocks have different cell number in the same direction, see the attached figure.
The diameter of the inner circle is 2 mm, and the outer circle has a diameter of 100 mm, 50 times larger than the inner one. Therefore, I need to give more cells in the circumferential direction of the outer circle. I don't have a clue to solve this problem now.
Is there any similar tutorial or example similar to this setup available?
Any suggestions or even the solutions will be appreciated
charryzzz is offline   Reply With Quote
Old   April 23, 2021, 10:33
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
Mesh the inner cylinder and outer annular geometry as separate unconnected regions. Then, couple these regions using ACMI patches.
GerhardHolzinger is offline   Reply With Quote
refine mesh
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
