[Salome] Cleaning up geometry in order to avoid "impossible to mesh periodic surface" error |
April 21, 2021, 13:11 |
Adam
Rep Power: 8 |
When meshing in gmsh I get the error "Impossible to mesh periodic surface 143" and then as a consequence there are "No elements in volume 1". I have reported this as a gmsh issue, and Christophe Geuzaine suggested that I try using Salome's healing routines. My geo and brep files can be found at the above link. Overall, my goal here is to generate a mesh of the spacing between the particles in a porous powder compact and then simulate the diffusion across the film. The contact points between particles generally leads to very low quality meshes. One of the global solutions is the simply shrink all the particles by a few percent. The meshing + simulation work fine when I do that. I would like to try a local method of using an inflated version of a particle as a boolean tool to cut its neighbors, leaving a small gap between the particles. More details can be found in this paper. I have narrowed an example of my problem down to a specific pair of spheres, where an inflated version of the small sphere is used as a Boolean tool to remove a portion of the larger sphere. Note that this specific pair is problematic when I apply a 5 mm inflation and cut, for other values the problem surface may be elsewhere. Code:
x = (0.122353, 0.155428) y = (0.104232, 0.104217) z = (0.761678, 0.799164) R= (0.04, 0.01) outerBox = geompy.MakeBox(0.1,0.1,0.75,0.2,0.15,0.85) I have had success with Salome's commands for removing extra edges in the isolated/two particle mesh. Code:
poreRepair = geompy.RemoveExtraEdges(poreSpace,True) poreRepair = geompy.RemoveExtraEdges(poreSpace,False) Does anyone have any suggestions about how to clean up my geometry in Salome, either before or after it's exported as a BREP file? |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 14:46 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 07:25 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 05:53 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
