[mesh manipulation] How to select faces in TopoSet based on faceCentres or faceLabels |
Sunag R A
Rep Power: 7 ![]() |
Dear All,
I have a surface mesh with temperature values applied on it from temperature profile data. In this, if there are 1000 temperature value, say 400 are zeros and rest are variables. I need to create a patch for this 400 faces which has 0 temp(FieldValue). I am thinking of using Toposet to access the faces and then create faceZoneSet and then use Createpatch for creating a patch. Later, once patch is done, I need to apply different BC on this temp = 0 faces. For this, how do the select the faces for toposet based on faceCentres or faceLabels. FaceCentres I can get through postProcessing after 1 simulation, which later can be changed. But how to use that in topoSet? Any leads will be appreciated. Regards, Sunag R A. |
createpatch, facecentre, toposet, toposetdict |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
