[snappyHexMesh] Skewed cells after snap
Old   April 8, 2021, 16:41
Default Skewed cells after snap
998gp is on a distinguished road
After I complete SHM, there are 4 cells at the corners of the geometry that are always skewed. I would expect them to be unskewed since blockMesh creates them but for some reason they always show up. Any idea what could be causing this?
Thanks
P
998gp is offline   Reply With Quote
Old   April 9, 2021, 02:41
M
AtoHM is on a distinguished road
What tells you that they are skewed?
AtoHM is offline   Reply With Quote
Old   April 9, 2021, 10:20
Good point.
Maybe my question should have been what causes them to have that shape. The underlying surface mesh? Snap settings?
Old   April 10, 2021, 13:14
M
You mean why are they not perfect cubes?
I do not know for sure, but, even if the background mesh covers that geometry 1:1 at that position, I can imagine there are still some minor deviations which causes the smoothing algorithm to slighty shift the nodes around. At least at the right side. Resolution of the used stl file could be a reason too, maybe.
At the left side, the first column of cells is obviously thinner than the ones next to it. So, I would guess the initial blockMesh was slightly bigger and then these cells were compressed a bit. However, all these cells are still near perfect, so nothing to worry about.
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
snappyHexMesh in parallel - FOAM Fatal IO Error mturcios777 OpenFOAM Running, Solving & CFD 4 August 10, 2012 20:18
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
