[blockMesh] Axisymmetric blockMesh for cylinder is failing checkMesh |
Bushra Rasheed
Rep Power: 5 ![]() |
Hi!
I am trying to make axisymmetric blockMesh for cylinder in Openfoam. I have made the mesh shown in attached picture but when I run checkMesh on it, it shows me 3 failed mesh checks. I have used mirrorMesh twice to mirror the mesh for one quarter cylinder that I had developed. The failed mesh checks are: ***Zero or negative face area detected. Minimum area: 0 <<Writing 1600 zero area faces to set zeroAreaFaces Min volume = 9.19428e-07. Max volume = 3.5858e-05. Total volume = 1.17687. Cell volumes OK. Mesh non-orthogonality Max: 90 average: 7.46455 ***Number of non-orthogonality errors: 1600. <<Writing 1600 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 63.6787, 720 highly skew faces detected which may impair the quality of the results <<Writing 720 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 3 mesh checks. I have not used type wedge in the quarter cylinder mesh since I mirrored it later. There are 0 default faces formed. Please help! |
axisymmetric mesh, axisymmetric wedge, blockmesh cylinder |
[blockMesh] blockMesh gives "Inconsistent point locations" for axisymmetric problem | irving | OpenFOAM Meshing & Mesh Conversion | 7 | January 27, 2021 12:31 |
[blockMesh] blockMesh and checkMesh with Wedges Issue | michu | OpenFOAM Meshing & Mesh Conversion | 3 | September 6, 2015 13:05 |
[mesh manipulation] strange result with blockMesh and checkMesh | dener | OpenFOAM Meshing & Mesh Conversion | 0 | August 22, 2013 08:40 |
BlockMesh CheckMesh error Help!!! | deepaktbabu | OpenFOAM | 0 | March 11, 2012 12:40 |
[blockMesh] Axisymmetric blockMesh error. Are Arcs needed? | andygdl | OpenFOAM Meshing & Mesh Conversion | 0 | November 2, 2010 11:25 |
