[blockMesh] ill defined primitiveEntry starting problem in blockMesh dict
Old   April 2, 2021, 09:19
Angry ill defined primitiveEntry starting problem in blockMesh dict
Mamun is on a distinguished road
hello everyone,
i am trying to simulate a 2d micro nozzle in open foam, its throat width 20 micrometer with expansion area ratio of 1.7 ( details in the attachment).
so, i tried to create my block Mesh dict with asymmetric of this geometry but i am getting a foam fatal error:
ill defined primitive Entry starting at keyword 'vertices' on line 20 and ending at line 107"
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1e-06;
vertices
(00.00 0.00 -0.033) //0
(50.00 0.00 -0.033) //1
(145.0 0.00 -0.033) //2
(145.0 10.0 -0.033) //3
(145.0 17.0 -0.033) //4
(50.00 10.0 -0.033) //5
(00.00 34.0 -0.033) //6
(00.00 10.0 -0.033) //7
(00.00 0.00 0.033 //8
(50.00 0.00 0.033) //9
(145.0 0.00 0.033) //10
(145.0 10.0 0.033) //11
(145.0 17.0 0.033) //12
(50.00 10.0 0.033) //13
(00.00 34.0 0.033) //14
(00.00 10.0 0.033) //15
blocks
hex (0 1 5 7 8 9 13 15) channelRegion (150 25 1) simpleGrading (1 1 1)
hex (1 2 3 5 9 10 11 13) channelRegion (300 25 1) simpleGrading (1 1 1)
hex (5 3 4 5 13 11 12 13) channelRegion (150 60 1) simpleGrading (1 1 1)
hex (7 5 5 6 15 13 13 15) channelRegion (150 40 1) simpleGrading (1 1 1)
edges
patches
empty
sides
(0 1 5 7)
(8 9 13 15)
(1 2 3 5)
(9 10 11 13)
(5 3 4 5)
(13 11 12 13)
(7 5 5 6)
(15 13 13 15)
symmetry
symmetry
(0 1 9 8)
(1 2 10 9)
wall
walls
(6 5 13 14)
(5 4 12 13)
patch
inlet
(0 8 15 7)
(7 15 14 6)
patch
outlet
(2 10 11 3)
(3 11 12 4)
mergePatchPairs
File Type: png Screenshot from 2021-04-02 21-06-37.png (14.6 KB, 5 views)
Mamun is offline   Reply With Quote
Old   April 2, 2021, 09:59
Yann
Yann will become famous soon enoughYann will become famous soon enough
Most of the time this error is related to a typo.
In your case, there is a closing bracket missing here:
Cheers,
Yann
Yann is offline   Reply With Quote
Old   April 3, 2021, 06:24
Default blockMesh dict
--> FOAM FATAL ERROR:
face 0 in patch 2 does not have neighbor cell face: 4(6 5 13 14)
after closing the bracket it's okay. but how to solve this one?
blockmesh dict, openfoam
[blockMesh] blockMesh gives "Inconsistent point locations" for axisymmetric problem irving OpenFOAM Meshing & Mesh Conversion 7 January 27, 2021 13:31
blockMesh problem when grading applied with cyclic patch broccolibadger OpenFOAM Pre-Processing 0 January 3, 2021 05:54
[blockMesh] BlockMesh: simpleGrading problem Dmarcohe OpenFOAM Meshing & Mesh Conversion 0 April 24, 2020 11:28
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
CFX 11 not starting - perl problem (Urgent) Luk CFX 12 August 18, 2009 10:31
