[mesh manipulation] Сombining stl surface meshes |
March 24, 2021, 11:36 |
Rep Power: 6 |
Hello!
There are different stl files. Their surfaces are randomly refined. It's supposed they are connected, because created using step files (check union.png). How can I unite them for getting a single external surface (single.png)? I can't use boolean operations in Gmsh, because stl format isn't supported there. If I simply add the start of second stl in first and then use cartesianMesh, I get problems at boundary. Do utilites like stitchMesh or mergeMeshes may help? I have read about them, but i'm not sure, how they should be used. Thanks! union.png |
March 25, 2021, 06:26 |
#2 | |
Rep Power: 15 |
I couldn't understand well. Would you like to merge the .stl files or the mesh created regarding those files? Second, wich meshing tool did you use to create the grids? |
March 31, 2021, 14:53 |
Rep Power: 6 |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 10:17 |
[mesh manipulation] extrudeMesh from STL Surface | TRT | OpenFOAM Meshing & Mesh Conversion | 1 | March 26, 2018 08:15 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 05:31 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
