[Gmsh] GmshToFoam
Old   March 22, 2021, 14:20
Default GmshToFoam
Zivota Lazarevic
zile96 is on a distinguished road
Hi everyone
I have a problem with conversion of Gmsh mesh to OpenFoam. GmshToFoam utility read physical names, points and cells form .msh file, but when generate "constant folder", there is no patches generated for every physical surface. There is only default patch0.
zile96 is offline   Reply With Quote
Old   March 25, 2021, 06:43
nasa55 is on a distinguished road
Originally Posted by zile96 View Post
Hi everyone
Have you specified both Physical Surface and Physical Volume for your geometry?
nasa55 is offline   Reply With Quote
Old   March 25, 2021, 06:52
Hi everyone
Have you tried with a different version of Gmsh? My experience is different from version to version and I suggest follow the tutorials in each version and don't mix them up.
Old   March 25, 2021, 06:54
Zivota Lazarevic
Yes, I did. I found the problem. For some reason, when I export .msh file, every element is assigned to physical group 0. That is why gmshToFoam makes one boundary condition.
Anyway, i found solution in exporting to .neu format from Gmsh, and then, with gambitToFoam conversion is done perfectly
Old   March 27, 2021, 06:58
Wassim Abdel Nour
wa$$im is on a distinguished road
I am glad you solved your problem.
But there is a much straighfoward way to do it.
Try specifying the physical groupements as nasa55 said. But verify you specified them well in tools->visibility before exporting the mesh.
This will certainly do it.
Regards.
wa$$im is offline   Reply With Quote
gmsh msh format converter, patch surface
[Gmsh] New version of gmshToFoam? stootoon OpenFOAM Meshing & Mesh Conversion 7 February 14, 2022 10:01
[Gmsh] gmshToFoam problem. nilashansen OpenFOAM Meshing & Mesh Conversion 11 June 5, 2016 11:45
[Gmsh] Cell to node connectivity after 'gmshToFoam' Jibran OpenFOAM Meshing & Mesh Conversion 1 June 8, 2015 10:09
[Gmsh] gmshTofoam pbm with cyclicAMI acahuzac OpenFOAM Meshing & Mesh Conversion 2 October 20, 2014 04:53
[Gmsh] gmshToFoam command mvinassa OpenFOAM Meshing & Mesh Conversion 1 April 25, 2014 08:36
