[snappyHexMesh] Meshed corner exceeds .stl surface - MultiRegion snap
Old   March 20, 2021, 13:46
Default Meshed corner exceeds .stl surface - MultiRegion snap
JeffFoam is on a distinguished road
Hey everyone,
I'm trying to mesh a multiRegion heat sink, solid and fluid, with chevron fins applied to the flow pattern. My problem is with meshing corners (see chevronDoubleMesh.jpg and chevronZoom.jpg) and edges (doubleMesh.jpg and entireMesh.jpg)
For the solid region (red surface in chevronDoubleMesh), the entire surface is supposed to be a fluid_to_solid Region, while for the fluid region (not visible in picture), this is solid_to_fluid. As you can see in chevronZoom.jpg, this problem occurs at several fins, but not all. It
I've tried changing most parameters in castellatedMeshControls and snapControls, as well as increasing the number of elements in the blockMeshDict.
Below you will find my snappyHexMeshDict of the chevron fins case.
Can anyone help me fix this?
snappyHexMeshDict.txt
JeffFoam is offline   Reply With Quote
edge, snap
[ICEM] Meshing .stl surface in ICEM kbodla ANSYS Meshing & Geometry 17 June 19, 2024 11:33
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
