[snappyHexMesh] Trade-off: bumpy surfaces versus checkMesh errors |
March 15, 2021, 08:26 |
Wouter
Rep Power: 13 |
Hi everyone,
please see the attached image - the mesh we get by experimenting with snappy looks very bumpy in some locations. https://imgur.com/a/re4MTAI We can get rid of most of the bumps by applying the following settings: - nSmoothPatch 5 - nSmoothInternal 5 - tolerance 2 - nRelaxIter 5 - maxBoundarySkewness 3 - maxInternalSkewness 2 But then we get quite a lot of errors (a lot is relative - about 2-10 problem cells on a 10 million cell mesh) in our checkMesh, mainly complaining about skewed faces, wrongOrientedFaces, negative volume pyramids. Interestingly, these errors often occur on the same cells, so they are linked - which means we don't exactly know which is the "real" error and what is causing it. We can reduce the number of problem cells by for example: - working with the same refinement level on the surface (so 6 6 instead of 5 6), as many bumps occur at the transition from one level to another. - further reducing the maxBoundarySkewness from 3 to 2 (but then we get a lot of bumps again) We've tried this on many models and haven't really found a reliable way to get a smooth surface mesh without introducing problem cells. Does anyone have the same experience and perhaps have some tips? |
How to use PIMPLE properly? | floquation | OpenFOAM Running, Solving & CFD | 27 | August 12, 2024 11:15 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
checkMesh / mesh errors | andybond13 | OpenFOAM Pre-Processing | 0 | June 10, 2015 14:05 |
[mesh manipulation] checkMesh Erros after refineMesh | mgdenno | OpenFOAM Meshing & Mesh Conversion | 10 | October 14, 2014 06:16 |
checkMesh Errors after refineMesh | mgdenno | OpenFOAM | 0 | July 30, 2012 22:39 |
