[snappyHexMesh] 'Pinching' of layers when transitioning from one thickness to another
Old   March 15, 2021, 07:10
Default 'Pinching' of layers when transitioning from one thickness to another
Mike Worth
MikeWorth is on a distinguished road
I'm trying to mesh a surface where at one particular end of the surface the layers need to extend further away from the wall. I think I'm almost there - I have 3 patches that represent the 'thin' and 'thick' regions plus a 'transition' region that avoids too abrupt a change. SHM can apply different thickness layers to these three bits, but the transitions are not smooth - the layers all get 'pinched' in towards the surface as shown in this image:
The definitions are calculated to have the same number of layers each (thinking that it would make for a nice one-to-one transition...) but with different start sizes and growth rates as follows:
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes false;
    // Per final patch (so not geometry!) the layer information
    layers
        thin
            //Calculated using https://openfoamwiki.net/index.php/Scripts/blockMesh_grading_calculation
            nSurfaceLayers 14;
            firstLayerThickness 5e-6;
            expansionRatio 1.258498951;
        transition
            nSurfaceLayers 14;
            firstLayerThickness 29e-6;
            expansionRatio 1.109512254;
        thick
            nSurfaceLayers 14;
            firstLayerThickness 78e-6;
            expansionRatio 1.033918581;
    // Expansion factor for layer mesh
    // Wanted thickness of final added cell layer. If multiple layers
    // is the
    // thickness of the layer furthest away from the wall.
    // Relative to undistorted size of cell outside layer.
    // is the thickness of the layer furthest away from the wall.
    // See relativeSizes parameter.
    //finalLayerThickness 1;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 4e-6;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 0;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 170;
    // At non-patched sides allow mesh to slip if extrusion direction makes
    // angle larger than slipFeatureAngle.
    slipFeatureAngle 30;
    // Maximum number of snapping relaxation iterations. Should stop
    // before upon reaching a correct mesh.
    nRelaxIter 3;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedialAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
Can anyone help me understand why this pinching exists, and how to get rid of it?
Many thanks,
Mike
MikeWorth is offline   Reply With Quote
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[snappyHexMesh] Collapsing layers RomCFD OpenFOAM Meshing & Mesh Conversion 5 January 18, 2020 02:39
[ANSYS Meshing] How Fluent calculates layers in First layer thickness asking ANSYS Meshing & Geometry 0 August 10, 2018 10:02
Volume mesh from layers in zero thickness walls nscomazzon ANSA 2 March 13, 2018 08:14
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
