[mesh manipulation] Full or half geometry to use?
Old   March 14, 2021, 08:31
Exclamation Full or half geometry to use?
Deutschland
vava10 is on a distinguished road
Hey.
I am simulating the ship flow. I am doing it using DTCHull Moving as a reference. I created almost all the changes required for my case setup.
When I came to DynamicMeshDict there was an entry for mass moment of inertia about the center of mass of the object.
In the DTCHull case setup they are using the whole geometry for the meshing purpose even though they are simulating the flow for half of the geometry. I tried to find if the moment of inertia is given for half or full geometry using solidwork and finding the moment of inertia but I could not find it because the values did not match
I am also simulating the flow for half of the geometry. My doubts are
1. Is it okay to use full geometry to create the mesh for the half simulation case
2. if I use full geometry does that mean I have to use moment of inertia for full geometry
This might be stupic question but I am in a confused loop
I thought since the simulation is going to determine the resistance on the hull batch specified in the mesh I should use the moment of inertia for half geometry in the beginning. But after seeing that the DTCHull used full geometry I am kinda confused
Please help me
Thanks in advance
vava10 is offline   Reply With Quote
[Workbench] Workbench 18.2 SpaceClaim->Mechanical geometry accuracy/tolerance problem sultzan ANSYS Meshing & Geometry 0 December 13, 2018 18:41
Results are not converging for Full Aircaft Geometry akki_malik SU2 11 September 24, 2018 12:21
[ICEM] Problem Meshing Asymmetrical Geometry Madhatter92 ANSYS Meshing & Geometry 1 December 23, 2017 06:56
How to mapfield a 2d axisymmetric field into a full 3d geometry silopes OpenFOAM Pre-Processing 0 April 3, 2013 12:42
3D geometry of round particles in a 2D half plane Stefan Zigan Main CFD Forum 0 January 10, 2008 05:00
