March 13, 2021, 12:35 |
inconsistent grading problem
hi i am quite novice to openfoam
i keep getting this error that i can not figure out how to correct --> FOAM FATAL ERROR: (openfoam-2012) Point merge failure between face 2 of block 8 and face 1 of block 9 Points: (0.500181 -0.500181 -0.5) (0.50903 -0.50903 -0.5) This may be due to inconsistent grading. From void Foam::blockMesh::calcTopologicalMerge() in file blockMesh/blockMeshMergeTopological.C at line 453. FOAM exitig this is my mesh file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant/polyMesh"; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 1; vertices ( (-5 -5 -0.5) (-1 -5 -0.5) (-1 -1 -0.5) (-5 -1 -0.5) (-5 -5 0.5) (-1 -5 0.5) (-1 -1 0.5) (-5 -1 0.5) (-1 1 -0.5) (-5 1 -0.5) (-1 1 0.5) (-5 1 0.5) (-1 5 -0.5) (-5 5 -0.5) (-1 5 0.5) (-5 5 0.5) (1 5 -0.5) (10 5 -0.5) (10 1 -0.5) (1 1 -0.5) (1 5 0.5) (10 5 0.5) (10 1 0.5) (1 1 0.5) (10 -1 -0.5) (10 -5 -0.5) (1 -5 -0.5) (1 -1 -0.5) (10 -1 0.5) (10 -5 0.5) (1 -5 0.5) (1 -1 0.5) (0.5 -0.5 -0.5) (0.5 0.5 -0.5) (-0.5 0.5 -0.5) (-0.5 -0.5 -0.5) (0.5 -0.5 0.5) (0.5 0.5 0.5) (-0.5 0.5 0.5) (-0.5 -0.5 0.5) ); blocks ( hex (0 1 2 3 4 5 6 7) (220 220 1) simpleGrading (1 1 1) hex (3 2 8 9 7 6 10 11) (220 220 1) simpleGrading (1 1 1) hex (9 8 12 13 11 10 14 15) (220 220 1) simpleGrading (1 1 1) hex (8 19 16 12 10 23 20 14) (220 220 1) simpleGrading (1 1 1) hex (1 26 27 2 5 30 31 6) (220 220 1) simpleGrading (1 1 1) hex (19 18 17 16 23 22 21 20) (220 220 1) simpleGrading (1 1 1) hex (27 24 18 19 31 28 22 23) (220 220 1) simpleGrading (1 1 1) hex (26 25 24 27 30 29 28 31) (220 220 1) simpleGrading (1 1 1) hex (32 27 19 33 36 31 23 37) (220 220 1) simpleGrading (50 1 1) hex (2 27 32 35 6 31 36 39) (220 220 1) simpleGrading (1 50 1) hex (2 35 34 8 6 39 38 10) (220 220 1) simpleGrading (50 1 1) hex (34 33 19 8 38 37 23 10) (220 220 1) simpleGrading (1 50 1) ); edges ( arc 35 34 (-0.7071067812 0 -0.5) arc 39 38 (-0.7071067812 0 0.5) arc 2 8 (-1.4142135624 0 -0.5) arc 6 10 (-1.4142135624 0 0.5) arc 34 33 (0 0.7071067812 -0.5) arc 38 37 (0 0.7071067812 0.5) arc 8 19 (0 1.4142135624 -0.5) arc 10 23 (0 1.4142135624 0.5) arc 33 32 (0.7071067812 0 -0.5) arc 37 36 (0.7071067812 0 0.5) arc 19 27 (1.4142135624 0 -0.5) arc 23 31 (1.4142135624 0 0.5) arc 32 35 (0 -0.7071067812 -0.5) arc 36 39 (0 -0.7071067812 0.5) arc 27 2 (0 -1.4142135624 -0.5) arc 31 6 (0 -1.4142135624 0.5) ); boundary ( inlet { type patch; faces ( (13 15 11 9) (9 11 7 3) (3 7 4 0) ); } outlet { type patch; faces ( (21 17 18 22) (22 18 24 28) (28 24 25 29) ); } obstacle { type wall; faces ( (38 34 35 39) (37 33 34 38) (36 32 33 37) (39 35 32 36) ); } tb { type symmetry; faces ( (15 13 12 14) (14 12 16 20) (20 16 17 21) (0 4 5 1) (1 5 30 26) (26 30 29 25) ); } frontAndBack { type empty; faces ( (7 6 5 4) (0 1 2 3) (11 10 6 7) (3 2 8 9) (15 14 10 11) (9 8 12 13) (14 20 23 10) (8 19 16 12) (6 31 30 5) (1 26 27 2) (20 21 22 23) (19 18 17 16) (23 22 28 31) (27 24 18 19) (31 28 29 30) (26 25 24 27) (37 23 31 36) (32 27 19 33) (39 36 31 6) (2 27 32 35) (10 38 39 6) (2 35 34 8) (10 23 37 38) (34 33 19 8) ); } ); mergePatchPairs ( ); // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // i really appreciate your help |
Is COMSOL Multi Physics is suitable to solve complex flow problem? | steve lee | COMSOL | 8 | January 5, 2023 03:31 |
Mesh& steptime independant: conduction-convection problem | Fati1 | Main CFD Forum | 1 | October 28, 2018 14:52 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
