[snappyHexMesh] How to generete internal domain from snappyHexMesh? |
March 3, 2021, 01:36 |
Sunag R A
Rep Power: 7 |
Dear All,
I have a set of 3D data points that looks similar to hemisphere. I converted these datapoints to traingulated surface using MeshLab and converted to stl file. 1. But, I need to close the bottom part of the domain as shown in the Image attached. I need to do internal heat transfer based on this domain. So, How to close the entire bottom surface so as to be used for simulation? 2. Alternatively, I tried working with blockmesh and snappyHexMesh thinking that the one surface of the blockmesh will covers the bottom surface of the stl mesh and give 3D internal mesh. Well, my idea was wrong. So, how to obtain only the internal domain along with closed surface at the bottom? I have attached the images link for reference. 1. Surface reconstructed from meshlab https://drive.google.com/file/d/13GJ...ew?usp=sharing 2. Bottom surface that need to be closed for further mesh and simulation https://drive.google.com/file/d/1ClD...ew?usp=sharing 3. Mesh obtained with BlockMesh and SnappyHexMesh https://drive.google.com/file/d/1FNZ...ew?usp=sharing Any leads will be appreciated. Regards, Sunag R A. |
blockmesh, internal, snappyhexmesh, stl, surface |
Internal Patches from SnappyHexMesh | twinturbotom | OpenFOAM Pre-Processing | 1 | December 2, 2017 20:53 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 23:38 |
[snappyHexMesh] snappyHexMesh and blockMesh for internal flow (leaking geometry?) | vaina74 | OpenFOAM Meshing & Mesh Conversion | 10 | November 20, 2014 10:14 |
[snappyHexMesh] Pipe flow / Internal fluid dynamics with SnappyHexMesh | denner | OpenFOAM Meshing & Mesh Conversion | 3 | October 13, 2011 10:24 |
[snappyHexMesh] SnappyHexMesh fails with internal Zones | chossfeld | OpenFOAM Meshing & Mesh Conversion | 1 | January 27, 2011 09:29 |
