[Commercial meshers] Simple rotating zone with AMI
Old   February 26, 2021, 11:51
Default Simple rotating zone with AMI
klitz is on a distinguished road
Hi everyone,
I am trying to use the AMI to simulate a simple rotating zone. I generated the mesh with Ansys meshing you can see:
I created the mesh with two different domains so there is no connection between the points. FOAM sees this connection as a wall. I searched this and I should create baffle from this internal wall I guess? I added the contact zone also:
I dont know what steps should I follow after converting the mesh or should rotating and static domains have connected nodes. I also added the mesh file if it helps.
klitz is offline   Reply With Quote
Old   August 3, 2023, 15:08
Sebastián Agudelo
sebastian0310 is on a distinguished road
Hi Klitz, were you able to solve this problem?
sebastian0310 is offline   Reply With Quote
Rotating Mesh - Mesh Overlap/Discontinuity At Boundary Interface sai95kamal FLUENT 1 June 15, 2020 09:58
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] Rotating Mesh and export Mesh ahmadreza ANSYS Meshing & Geometry 10 July 12, 2015 05:17
[snappyHexMesh] 2D AMI Moving Mesh with sHM; How hard can this be? ADGlassby OpenFOAM Meshing & Mesh Conversion 18 June 18, 2013 07:07
