[blockMesh] Creating a geometry using Blockmesh
Old   February 25, 2021, 16:03
Default Creating a geometry using Blockmesh
ulugbey is on a distinguished road
I need to create a geometry using the blockMesh. But I don`t have too much idea how to create this geometry using blockMesh. How many blocks should I generate?
I add the geometry. Could you give me an idea about that? I appreciate your helps.
ulugbey is offline   Reply With Quote
Old   February 26, 2021, 05:41
anonymous
simrego is on a distinguished road
Hi
You can do it with 4 blocks and use arc for the edges.
But it seems like you could just create an axisymmetric domain.
simrego is offline   Reply With Quote
Old   February 26, 2021, 07:56
Is there a difference if I do it with 8 blocks?
Old   February 26, 2021, 08:18
anonymous
You can do it from at least 3 blocks. As I remember with 2 blocks you can't do it. It'll throw an error.
But with 3 blocks you will have ugly vertex coordinates, but with 4 blocks you will have the least blocks with "nice" vertex coordinates.
I shouldn't do it with more blocks since you will just make more useless work for yourself.
Or you can even create a quarter section and use symmetry patches. Then you will have one block.
So no, there won't be any difference if you divide it into 8 sections and create 8 blocks. But you won't have a "better" mesh, just more vertices, more blocks, more patches("block sides") -> more error sources...
blockmesh, openfoam 2.1.1
[Gmsh] Creating 2 baffles in geometry caja94 OpenFOAM Meshing & Mesh Conversion 1 October 7, 2018 05:05
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 11:44
[ICEM] Creating mesh for fluid - solid geometry tmu ANSYS Meshing & Geometry 1 March 5, 2016 07:14
Problem with building geometry - concentric cylinders Rhoddwen OpenFOAM Pre-Processing 9 December 17, 2014 11:02
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
