[Other] Looking for a more in-depth explanation of boundary types |
February 21, 2021, 23:27 |
Homer Bacanto
Rep Power: 6 |
Hello all,
I am very much a beginner to CFD, and would like to know if there are any resources I can read for a more in depth explanation of OpenFOAM boundary types. For example, what exactly is a patch? How does it behave when experiencing varying levels of pressure? And how does the boundary type of patch differ from a boundary type of wall? I'd be grateful if anyone can point me in the right direction. Thank you! |
February 28, 2021, 01:20 |
#2 | |
Catalin
Rep Power: 6 |
Before anything else, read the manual and run the cases presented there. You will learn a lot from that. To your question, read the mesh section of it. You will learn that a patch is group of faces having the same functionality. Try looking in the source code online as it has links to every entity of it. It will take a while to get used to it but in the end you will see the light. You don't need to understand everything there or know c++ to move things around. Give it a try and be patient. Catalin Last edited by aghora17; February 28, 2021 at 07:45. |
March 6, 2021, 15:03 |
Herpes Free Engineer
Rep Power: 13 |
Hi, I would dive into the links below. Hope those help.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
openfoam |
UDF for Automatic Solution Initialization for previous case data file | gartz89 | Fluent UDF and Scheme Programming | 6 | March 30, 2020 08:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
