[snappyHexMesh] How to assign consistently master/slave cyclics with createPatch |
January 28, 2021, 06:26 |
Edoardo Gamba
Rep Power: 6 |
Hi everyone, I'm working on a simpleFoam case of a FSAE car, I have modeled 3 fans using the fixedJump BC (also tried fanPressure with the fan curves but i get a lot of convergence problems).
I start from a surface stl of the fan, mesh it as a baffle in snappyHexMesh and then with createPatch i transform it into 2 couple patches, then with changeDictionary i set them as cyclics and apply the fixedJump BC. My problem is really simple, createPatch chooses randomly who's master and who's slave, so in the end I have a 50% chance my fan is set up right (the jump needs to go in the +x direction). Does anyone have an idea on how to make createPatch call master the patch on the -x side and slave the one opposite to it? This problem is wasting my time since I have to check if the fan is actually blowing air and if it's not I need to use a changeDictionary just to change its fixedJump to a negative one to reverse the flow. Thanks in advance |
createpatch, fixedjump, openfoam, snappyhexmesh |
[mesh manipulation] createpatch not working when using layer addition in snappyHexMesh | Dikkeunit | OpenFOAM Meshing & Mesh Conversion | 0 | February 3, 2020 09:46 |
There is a bug in createPatch? | feno102 | OpenFOAM Pre-Processing | 6 | November 1, 2017 02:24 |
OF ext-3.2 new createPatch cyclics issue | Jack001 | OpenFOAM Pre-Processing | 0 | May 26, 2016 14:43 |
