January 27, 2021, 10:16 |
gmshToFoam conversion issue!
Johny_walker
Rep Power: 6 |
I am getting the following error on converting my gmsh mesh file to foam:
Create time Starting to read mesh format at line 2 Read format version 2.2 ascii 0 Starting to read physical names at line 5 Physical names:6 Surface 1 inlet Surface 2 outlet Surface 3 topAndBottomWalls Surface 4 frontAndBack Surface 5 cylwall Volume 6 internal Starting to read points at line 14 Vertices to be read:18320 Vertices read:18320 Starting to read cells at line 18337 Cells to be read:36286 Mapping region 4 to Foam patch 0 Mapping region 1 to Foam patch 1 Mapping region 3 to Foam patch 2 Mapping region 2 to Foam patch 3 Mapping region 5 to Foam patch 4 Cells: total:0 hex :0 prism:0 pyr :0 tet :0 --> FOAM FATAL IO ERROR: No cells read from file "untitled.msh" Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)? Perhaps you have not exported the 3D elements? file: untitled.msh at line 54625. From function void readCells(Foam::scalar, bool, const pointField&, const Foam::Map<int>&, Foam::IFstream&, Foam::cellShapeList&, Foam::labelList&, Foam::List<Foam:ynamicList<Foam::face> >&, Foam::labelList&, Foam::List<Foam:ynamicList<int> >&) in file gmshToFoam.C at line 726. FOAM exiting Can anyone tell me why is it so? .Geo and .msh files can be accessed through: https://www.dropbox.com/sh/t01a4gvxh...DgGOmmjua?dl=0 Regards |
February 24, 2021, 02:52 |
Asmaa
Rep Power: 10 |
You simply need to add a volume in physical group ( Geometry --> Physical Groups --> Add --> Volume). For the mesh generation, you need to generate a mesh of version 2.2 compatible for OpenFoam conversion, for this use the command: gmsh -3 -format msh2 unitled.geo For the mesh conversion: gmshToFoam untitled.msh The created volume appears in OpenFoam as a cellzone. |
April 15, 2022, 14:46 |
Problems fixed!!??
Saketh Bharadwaj
Rep Power: 8 |
I came across a similar problem but could not solve it. I created another thread. Can someone help me fix this. Gmsh import into OpenFOAM |
gmsh to openfoam, mesh 2d |
[Gmsh] GMSH to OpenFOAM file conversion error (GmshToFoam) | Nikhil Bollimuntha | OpenFOAM Meshing & Mesh Conversion | 4 | May 18, 2019 09:29 |
[Gmsh] No 3D Element found during gmshToFoam conversion | bhargav1195 | OpenFOAM Meshing & Mesh Conversion | 1 | June 21, 2018 10:37 |
Convergence issue in natural convection problem | chrisf90 | FLUENT | 5 | March 5, 2016 09:30 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 09:27 |
[Gmsh] gmshToFoam issue | tomhebunn | OpenFOAM Meshing & Mesh Conversion | 3 | April 16, 2011 09:08 |
