[blockMesh] Cant use blockMesh on cylinder tutorial with macOS
Old   January 26, 2021, 13:43
Default Cant use blockMesh on cylinder tutorial with macOS
Kim Best
KimBest is on a distinguished road
I'm new to openFoam and am going through the tutorials with macOS 10.14.6. When I enter the potentialFoam Cylinder tutorial ($FOAM_TUTORIALS/basic/potentialFoam/cylinder), I run blockMesh and get the following output:
[ofuser@f6067f688c69 cylinder]$ blockMesh
| \\ / O peration | Version: 2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _79e353b8-20201222 OPENFOAM=2012
Arch : "LSB;label=32;scalar=64"
Exec : blockMesh
Date : Jan 26 2021
Time : 17:27:57
Host : f6067f688c69
PID : 847
I/O : uncollated
Case : /home/ofuser/workingDir/cylinder
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from "system/blockMeshDict"
Using #codeStream at line 23 in file "/home/ofuser/workingDir/cylinder/system/blockMeshDict"
Using #codeStream with "/home/ofuser/workingDir/cylinder/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_49e41d753f2adb4c8dffc0259424b06af57d b063.so"
Could not load "/home/ofuser/workingDir/cylinder/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_49e41d753f2adb4c8dffc0259424b06af57d b063.so"
/home/ofuser/workingDir/cylinder/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_49e41d753f2adb4c8dffc0259424b06af57d b063.so: cannot open shared object file: No such file or directory
Invoking wmake libso /home/ofuser/workingDir/cylinder/dynamicCode/_49e41d753f2adb4c8dffc0259424b06af57db063
--> FOAM FATAL ERROR: (openfoam-2012)
exec(wmake, ...) failed
From int Foam::system(const Foam::CStringList&, bool)
in file POSIX.C at line 1628.
FOAM exiting
Segmentation fault
I suspect it's something to do with the installation from seeing similiar errors on other threads, however I can't work out what to do as I'm not running on windows or linux etc. I did the installation exactly according to the openfoam instructions with docker (https://www.openfoam.com/download/in...binary-mac.php), and when I execute docker images to check if its done right, I get the following:
"REPOSITORY TAG IMAGE ID CREATED SIZE
openfoamplus/of_v2012_centos73 release 8c2e256b99c8 2 weeks ago 1.99GB
openfoam/openfoam8-paraview56 latest be19d87c75fc 2 months ago 2.57GB
openfoam/openfoam8-graphical-apps latest c2e1cd53823d 2 months ago 1.76GB"
I think the installation is therefore okay. Hope someone can help. Thank you
KimBest is offline   Reply With Quote
Old   January 27, 2021, 10:54
Sophie
So_LL is on a distinguished road
Hi !
I am rather new to OpenFOAM as well but from what I understand so far, most files in OpenFOAM, I am thinking probably the tutorials files too, are locked (including all the solvers and other utilities). So to complete a tutorial and run blockMesh, the case files should be copied over in your "run" folder first.
That's what I would try anyway !
Good luck !
So_LL is offline   Reply With Quote
Old   February 7, 2021, 09:07
Kim Best
Hi, thank you for the reply. I tried that as well but I get the same error unfortunately . Also, what might be of interest is that I get the same error when I run blockMesh for the case 'bump2D', among some others. So the installation seems to have worked for some cases but not others.
Old   February 9, 2021, 12:03
Kim Best
I think the problem is that I need to download make for mac in order to be able to run the dynamic code in blockMeshDict. I have done this using homebrew but I'm not sure where to go from here as it's still not making any difference. Any a help on this one would be great!
blockmesh cylinder, mac os, wmake error
[blockMesh] Unable to run blockMesh for tutorial "cylinder" in OpenFoam bharadwaj1729 OpenFOAM Meshing & Mesh Conversion 4 July 22, 2018 14:03
Cylinder tutorial robbo OpenFOAM Running, Solving & CFD 39 June 7, 2018 08:07
[blockMesh] Error while using blockMesh tutorial!! ssrivas3 OpenFOAM Meshing & Mesh Conversion 0 May 22, 2017 14:32
[ICEM] Cylinder meshing tutorial Far ANSYS Meshing & Geometry 28 April 17, 2012 07:44
[ICEM] Cylinder meshing tutorial Far ANSYS Meshing & Geometry 2 April 2, 2012 23:10
