[mesh manipulation] How to separate frontAndBack |
January 25, 2021, 23:20 |
Rep Power: 10 |
Hello all,
I have a 2D mesh from fluent. When I run fluentMeshToFoam, it is automatically converted to a single layer 3D mesh. The front and back planes are combined in a single patch named "frontAndBackPlanes". There is a tutorial that splits the boundary patch: patch splitting for different boundary conditions However, since "front" and "back" patches share the same cell, this trick doesn't work. I know that the ultimate solution is to make a single-layer 3D mesh in fluent but is there any workaround to do it within OpenFOAM? Thanks! |
January 26, 2021, 09:51 |
anonymous
Rep Power: 14 |
Hi!
Maybe it is a silly question, but why do you need to split it? 2D mesh -> front and back are empty, and you will need the same BCs there. Also you shouldn't evaluate anything there so I think there is no reason for that. BTW: check the topoSet and createPatch utlities. |
January 26, 2021, 10:42 |
#3 | |
Rep Power: 10 |
Or is there anyway to get a 2D face patch from Fluent directly? |
January 26, 2021, 10:53 |
anonymous
Rep Power: 14 |
Well. Then it would be nicer to do it with blockMesh.
As I know you can't do it. So it this case I would go with topoSet+createPatch and extrude that patch. Or simply do it in fluent which is the easiest way. And as you originally asked: "is there any workaround to do it within OpenFOAM?" Yes, there is a workaround for nearly everything in OpenFOAM, but in the worst case you have to code a little. |
fluentmeshtofoam |
Running multiple separate Serial runs on separate cores | FlyBoy38L | SU2 | 0 | July 1, 2019 13:48 |
Separate cells by IsoSurface? | vidyadhar | FLUENT | 1 | June 18, 2019 08:15 |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
[DesignModeler] Creating Two Separate Bodies in Design Modeller | ashtonJ | ANSYS Meshing & Geometry | 39 | June 6, 2018 17:31 |
[Commercial meshers] import two separate gambit mesh file for solid and fluid regions | rapierrz | OpenFOAM Meshing & Mesh Conversion | 0 | December 31, 2015 10:26 |
