[blockMesh] --> FOAM FATAL ERROR: Trying to specify a boundary face 4(11 26 25 10) |
January 14, 2021, 20:20 |
Axel Dorian
Rep Power: 8 |
Hello Community,
I have an issue with my blockMeshDict file. When I lunch blockMesh it gives me the following error: --> FOAM FATAL ERROR: Trying to specify a boundary face 4(11 26 25 10) on the face on cell 1 which is either an internal face or already belongs to some other patch. This is face 0 of patch 0 named inlet. From function polyMesh::setTopology ( const cellShapeList& cellsAsShapes, const faceListList& boundaryFaces, const wordList& boundaryPatchNames, labelList& patchSizes, labelList& patchStarts, label& defaultPatchStart, label& nFaces, cellList& cells ) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 357. FOAM aborting Aborted (core dumped) I have been trying to solve the issue with no avail. Please someone to help. Please find in attach my blockmesh file. Thanks much. Axel |
January 17, 2021, 01:37 |
issues with curvatures faces on blockMeshDict
Axel Dorian
Rep Power: 8 |
Hello all,
I am building a pre-existing fracture geometry (as in the figure in attached) and I am facing issues on the inlet faces which are curves faces. Here below is the error: --> FOAM FATAL ERROR: Trying to specify a boundary face 4(11 26 25 10) on the face on cell 1 which is either an internal face or already belongs to some other patch. This is face 0 of patch 0 named inlet. The blockMeswhDict File is in the previous post. Please help me out with issue. I have trying to solve the problem without any solution. Best Regards, Axel |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 16:02 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
