[Salome] Axis symmetric stitchMesh issue
Old   January 13, 2021, 07:08
Default Axis symmetric stitchMesh issue
Shivam Singhal
Shivam Singhal is on a distinguished road
I want to create Axisymmetric Mesh for my simulation.
I have created 2D Mesh (one cell thick) in salome and exported it to OpenFOAM using ideasUnvToFoam. I am able to use extrude mesh and create wedge BC, but when I am executing stitchMesh command, I am getting attached error. I have searched the entire internet but couldn't find any help .Your help is highly appreciated.
Create time
Create mesh for time = 0
Coupling perfectly aligned patches front and back
Resulting (internal) faces will be in faceZone frontbackCutFaceZone
Note: both patches need to align perfectly.
Both the vertex positions and the face centres need to align to within
a tolerance given by the minimum edge length on the patch
Adding faceZone frontbackCutFaceZone at index 0
Reading all current volfields
Reading volScalarField p_rgh
Reading volScalarField alpha.water
Reading volVectorField U
--> FOAM FATAL ERROR:
This is not allowed.
Face: 4(10200 10203 10202 10201) faceID:30000 owner:0 neighbour:0
From function Foam:olyModifyFace:olyModifyFace(const Foam::face&, Foam::label, Foam::label, Foam::label, bool, Foam::label, bool, Foam::label, bool)
in file ./polyTopoChange/polyTopoChange/modifyObject/polyModifyFace.H at line 154.
FOAM aborting
We're sorry, but the application crashed and safe stack tracing isn't available in this current implementation of blueCFD-Core patches for OpenFOAM.
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Shivam Singhal is offline   Reply With Quote
stitchmesh patch
Result Symmetry issue zrpanah FLUENT 0 October 27, 2016 15:36
horizontal axis wind turbine- Issue in interface b/w stationary and rotating domain. srijithbbk CFX 5 February 22, 2016 05:20
[Other] dynamic Mesh with angular velocity not parallel to x axis donQi OpenFOAM Meshing & Mesh Conversion 5 October 3, 2014 00:19
coordinate of axis symmetric model(beginner) hamid723 Fluent UDF and Scheme Programming 0 March 27, 2014 02:54
proper macro for axis symmetric problem ayousefi Fluent UDF and Scheme Programming 0 February 24, 2014 10:40
