[snappyHexMesh] How do I put STL files in interFoam? |
January 12, 2021, 03:12 |
seo
Rep Power: 5 |
Hello. It's only been a week since I learned Openfoam.
I am currently doing a tutorial using the dambreak in the interFoam. I have a question. The tutorial contains blockmesh of dambreak, but I would like to use Solidworks and STL files to add mesh directly. I don't know even if I look for several videos. Could you tell me how to put the STL file into the interfoam easily? Or do you have a tutorial? |
January 13, 2021, 10:06 |
Rep Power: 10 |
You can use snappyHexMesh for that. It's shown for example in the motorBike tutorial.
#interfoam #dambreak #stl |
[mesh manipulation] topoSet for stl files | Owais Shabbir | OpenFOAM Meshing & Mesh Conversion | 4 | November 8, 2020 17:42 |
[snappyHexMesh] With FreeCAD: creating waterproof STL files? | robob | OpenFOAM Meshing & Mesh Conversion | 11 | April 29, 2018 11:33 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 05:58 |
How to create inlet/outlet/wall STL files from a STL CAD model | Gentible | Mesh Generation & Pre-Processing | 1 | June 23, 2015 10:18 |
[snappyHexMesh] Convert stl files and multi region | abrunet | OpenFOAM Meshing & Mesh Conversion | 1 | July 1, 2014 10:15 |
