[mesh manipulation] cell aspect ratio of 1:1:1 for snappy region |
November 3, 2020, 14:35 |
David
Rep Power: 6 |
Hi foamer
I need to achieve a cell aspect ratio 1:1:1 at the snappy region of my background mesh to the geometry at my ground. A I am able to adopt a previous code which already achieved this but I had to split the domain into two boxes, a near ground region and a ceiling region. My question now is, how can I achieve this in the best way? I am quite new to the entire CFD universe and so I am a bit confused. My approach would have been just to take the same multi-graded mesh in both boxes an keep the same amount of cells. As my near ground region is much smaller this would have the desired effect of having the finer mesh in this region. However I am firstly not quite sure if this fulfill the requirement of the desired cell aspect ratio and secondly I think this would not be a efficient solution.... So my blockMeshDict is right now this: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // backgroundMesh { xMin 1.9; // L = xMax 8.3; yMin 0.0054; // L = yMax 1.9; zMin 0; //-0.01875 zTree 0.0.09375; //15m/160 zMax 1.61675; //1.6 xCells 141; //141 800 yCells 62; //62 200 zCells 32; //32 200 } //convertToMeters 1; vertices ( ($:backgroundMesh.xMin $:backgroundMesh.yMin $:backgroundMesh.zMin) //0 ($:backgroundMesh.xMax $:backgroundMesh.yMin $:backgroundMesh.zMin) //1 ($:backgroundMesh.xMax $:backgroundMesh.yMax $:backgroundMesh.zMin) //2 ($:backgroundMesh.xMin $:backgroundMesh.yMax $:backgroundMesh.zMin) //3 ($:backgroundMesh.xMin $:backgroundMesh.yMin $:backgroundMesh.zMax) //4 ($:backgroundMesh.xMax $:backgroundMesh.yMin $:backgroundMesh.zMax) //5 ($:backgroundMesh.xMax $:backgroundMesh.yMax $:backgroundMesh.zMax) //6 ($:backgroundMesh.xMin $:backgroundMesh.yMax $:backgroundMesh.zMax) //7 ($:backgroundMesh.xMin $:backgroundMesh.yMin $:backgroundMesh.zTree) //8 new 4 ($:backgroundMesh.xMax $:backgroundMesh.yMin $:backgroundMesh.zTree) //9 new 5 ($:backgroundMesh.xMax $:backgroundMesh.yMax $:backgroundMesh.zTree) //10 new 6 ($:backgroundMesh.xMin $:backgroundMesh.yMax $:backgroundMesh.zTree) //11 new 7 ); blocks ( hex (0 1 2 3 8 9 10 11) //0 1 2 3 4 5 6 7 domain of ground to zTree ( $:backgroundMesh.xCells $:backgroundMesh.yCells $:backgroundMesh.zCells ) simpleGrading ( ( (0.109375 0.085106383 0.3) // l% x-dir, % cells, expansion = (0.53125 0.780141844 1) // l% x-dir, % cells, expansion = (0.359375 0.134751773 10) // l% x-dir, % cells, expansion = ) 1 // y-direction expansion ratio ( (0.1572376 0.375 1) // z% x-dir, % cells, expansion = (0.8427624 0.625 8) // z% x-dir, % cells, expansion = ) ) hex (8 9 10 11 4 5 6 7) //0 1 2 3 4 5 6 7 domain of zTree to ceilling hex (8 9 10 11 4 5 6 7) ( $:backgroundMesh.xCells $:backgroundMesh.yCells $:backgroundMesh.zCells ) simpleGrading ( ( (0.109375 0.085106383 0.3) // l% x-dir, % cells, expansion = (0.53125 0.780141844 1) // l% x-dir, % cells, expansion = (0.359375 0.134751773 10) // l% x-dir, % cells, expansion = ) 1 // y-direction expansion ratio ( (0.1572376 0.375 1) // z% x-dir, % cells, expansion = (0.8427624 0.625 8) // z% x-dir, % cells, expansion = ) ) ); edges ( ); boundary ( inlet { type patch; faces ( (0 3 11 8) (8 11 7 4) //(0 3 7 4) ); } outlet { type patch; faces ( (1 9 10 2) (9 5 6 10) //(1 5 6 2) ); } ground { type wall; faces ( (0 1 2 3) //(0 1 2 3) ); } frontAndBack { type wall; faces ( (0 8 9 1) (8 4 5 9) //front (0 4 5 1) (3 2 10 11) (11 10 6 7) //back (3 2 6 7) (4 7 6 5) //ceilling (4 7 6 5) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg" castellatedMesh on; snap on; addLayers off; geometry { GltbuildingclusterWindtunnel.stl { scale 0.001; type triSurfaceMesh; name GltbuildingclusterWindtunnel; } }; castellatedMeshControls { // nCellsBetweenLevels 3; features ( { file "GltbuildingclusterWindtunnel.eMesh"; level 3; scale 0.001;} ); refinementSurfaces { GltbuildingclusterWindtunnel { level (2 3); patchInfo { type wall; } } } refinementRegions { GltbuildingclusterWindtunnel { mode distance; levels ((0.077 2)); } } locationInMesh (2 1 1); resolveFeatureAngle 60; allowFreeStandingZoneFaces true; } snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric) features by sampling the surface (default=false) implicitFeatureSnap true; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap false; } addLayersControls { layers { "CAD.*" { nSurfaceLayers 2; } } relativeSizes true; expansionRatio 1.2; finalLayerThickness 0.5; minThickness 1e-3; } meshQualityControls { maxConcave 70; minTetQuality 1E-12; maxInternalSkewness 5; maxBoundarySkewness 25; } writeFlags ( scalarLevels layerSets layerFields ); mergeTolerance 1e-6; // ************************************************************************* // Many thanks already in advance!! Best fid Last edited by fidu; November 4, 2020 at 08:03. |
blockmeshdict, cell aspect ratio, simplegrading, snapphexmesh |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
mesh of large aspect ratio region | marangoni | FLUENT | 0 | May 25, 2003 00:18 |
