September 9, 2020, 09:12 |
cell selection_Leakage simulation
Nikhil
Rep Power: 6 |
Hallo foamers,
I am trying to simulate a leakage of propane from a storage tank. my doudt over here is, can i define the whole leak in one cell, i.e., propane flow rate is defined in a single cell (area=270mm˛) of the mesh, (or) is it better to define the same leak with multiple cells, i.e., select 4 (example) mesh cells (area=270mm˛) together and define leak. Both has singnificant effect on the results (cloud formation). Which way, is right and why? cheers, nm. |
dispersion, hvac, leak simulation |
fuel cell simulation in Fluent | Huang | FLUENT | 19 | July 2, 2024 10:04 |
simulation of Proton exchange membrane fuel cell by CFD | Asifa Awan | Main CFD Forum | 0 | August 26, 2017 16:54 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 05:27 |
Simulation time vs. Simulation Cell Count | chrisoturner | Main CFD Forum | 7 | September 8, 2012 18:46 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
