[mesh manipulation] stitchMesh Not Working Properly
Old   July 22, 2020, 13:09
Default stitchMesh Not Working Properly
Semih Batuhan Candir
leuthar is on a distinguished road
Hello everyone,
I'm trying to create a model to study damBreak case, but I want to refine my mesh manually where it is needed. I tried using refineMesh, but was not able to refine my mesh the way I wanted. So, I decided using stitchMesh, but I'm facing a problem this time. I've created 4 simple blocks to understand how it works, general structure of the model is one block is placed on top of another one and then, two identical blocks are placed just next to them. I've managed to merge top and bottom faces of the blocks using mergePatchPairs in blockMesh file and created a boundary layer between two block pairs namely right1 and left1. I'm trying to make these two layers internal so that water can freely pass through these faces, but even though there is no errors in the process, I'm getting an error in ParaView that my mesh and field points doesn't match. I've looked up for stitchMesh a bit and figured out I should see nFaces as 0 in boundary file, but this is not the case for me. If you could help me figure out what is the problem or any kind of advice that you think might be useful is very much appreciated.
I'm attaching a screenshot to visualize my intention.
Here is my blockMesh file;
|  \\    /   O peration     | Version:  v1912                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
scale   1.000;
x1 0.00;
x2 5;
x3 10;
y1 0.00;
y2 5;
y3 10;
z1 0.00;
z2 5;
z3 10;
vertices
    ($x1 $y1 $z1) // 0
    ($x2 $y1 $z1) // 1
    ($x2 $y2 $z1) // 2
    ($x1 $y2 $z1) // 3
    ($x1 $y1 $z2) // 4
    ($x2 $y1 $z2) // 5
    ($x2 $y2 $z2) // 6
    ($x1 $y2 $z2) // 7
	// block0
    ($x1 $y1 $z2) // 8
    ($x2 $y1 $z2) // 9
    ($x2 $y2 $z2) // 10
    ($x1 $y2 $z2) // 11
    ($x1 $y1 $z3) // 12
    ($x2 $y1 $z3) // 13
    ($x2 $y2 $z3) // 14
    ($x1 $y2 $z3) // 15
	// block1
    ($x2 $y1 $z1) // 16
    ($x3 $y1 $z1) // 17
    ($x3 $y2 $z1) // 18
    ($x2 $y2 $z1) // 19
    ($x2 $y1 $z2) // 20
    ($x3 $y1 $z2) // 21
    ($x3 $y2 $z2) // 22
    ($x2 $y2 $z2) // 23
	// block2
    ($x2 $y1 $z2) // 24
    ($x3 $y1 $z2) // 25
    ($x3 $y2 $z2) // 26
    ($x2 $y2 $z2) // 27
    ($x2 $y1 $z3) // 28
    ($x3 $y1 $z3) // 29
    ($x3 $y2 $z3) // 30
    ($x2 $y2 $z3) // 31
	// block3
blocks
    hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1)			// 0
    hex (8 9 10 11 12 13 14 15) (20 20 20) simpleGrading (1 1 1)		// 1
    hex (16 17 18 19 20 21 22 23) (20 20 20) simpleGrading (1 1 1)		// 2
    hex (24 25 26 27 28 29 30 31) (10 10 10) simpleGrading (1 1 1)		// 3
edges
boundary
    leftWall
        type wall;
        faces
            (0 3 7 4)
            (8 11 15 12)
    rightWall
        type wall;
        faces
            (21 22 18 17)
            (29 30 26 25)
    lowerWall
        type wall;
        faces
            (0 1 2 3)
            (16 17 18 19)
    sideWall
        type wall;
        faces
            (3 2 6 7)
	    (11 10 14 15)
            (19 18 22 23)
	    (27 26 30 31)
    symmetry
        type symmetryPlane;
        faces
            (4 5 1 0)
            (12 13 9 8)
            (20 21 17 16)
            (28 29 25 24)
    atmosphere
        type patch;
        faces
            (12 15 14 13)
            (28 31 30 29)
// Internal Boundaries
    internal1
        type patch;
        faces
            (4 7 6 5)
    internal2
        type patch;
        faces
            (8 9 10 11)
    internal3
        type patch;
        faces
            (20 23 22 21)
    internal4
        type patch;
        faces
            (24 25 26 27)
// Internal Faces that cannot be merged
    right1
        type wall;
        faces
            (5 6 2 1)
            (13 14 10 9)
    left1
        type wall;
        faces
            (16 19 23 20)
            (24 27 31 28)
mergePatchPairs
	    (internal1 internal2)
	    (internal3 internal4)
And this is the stitchMesh file I'm trying to use,
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      stitchMeshDict;
right1
    match   perfect;    // partial | integral | perfect
    master  right1;
    slave   left1;
I have also tried "partial" and "integral" options for matching, but none of them seem to solve my problem. Please let me know if you need any further information.
leuthar is offline   Reply With Quote
Old   August 11, 2020, 20:58
Claudio Boezio
Ship Designer is on a distinguished road
Hello leuthar,
I propose the following:
  • Use stitchMesh with the option -noFields. This prevents it from even looking at any fields possibly present in the 0 folder and complain about not matching mesh, points etc.
  • Check whether after using stitchMesh there's a file meshPhi in the 0 folder. If so, try deleting it and see if ParaView still reports an error. I recommend deleting it also before running stitchMesh.
From your description I haven't understood if the patches in the end are matched properly or not. An easy way to inspect this is by looking at internalField in ParaView and set it to a reduced opacity. If you can see internal patches shining through, they are not matched. Also, if all the matched patches bother you in ParaView's Mesh Regions list, you can tidy it up by executing createPatch with an empty createPatchDict dictionary after meshing. This won't create new patches but remove from the polyMesh/boundary file all patch entries with 0 faces and correct the patches count. So the list will be neat with only the patches you need for your simulation. Hope this helps. Please let me know how it goes.
Ship Designer is offline   Reply With Quote
Old   November 30, 2020, 08:30
Rango is on a distinguished road
Stitching/merging patches can be tricky for this case. Either it is a bug or a limitation with the application (see the threads below for more details):
Post#5: Face reduced to less than 3 points (simple cubic blocks)
Post#9 and Post#25: when can stitchMesh be used?
I renamed (and re-arranged) the patches in your blockMeshDict (just minor changes), and managed to remove the internal boundaries between different regions by performing:
blockMesh
stitchMesh -partial part1and2_to_part3and4 part3and4_to_part1and2 -overwrite
Then you can delete empty patches from your 'boundary' file. The case and snapshots of the mesh have been attached (I have used OpenFOAM 5.x for this case).
Cheers
Rango is offline   Reply With Quote
potentialFoam not working properly GAlava OpenFOAM Running, Solving & CFD 7 March 9, 2021 12:34
Is there any institutions still working on solving N-S equations? sharonyue Main CFD Forum 2 November 11, 2015 09:23
what "If" condition means in rebound brbbhatti OpenFOAM Programming & Development 0 August 12, 2014 10:18
Slip BC not working properly lfbarcelo OpenFOAM 3 July 15, 2010 10:53
Sample utility not working properly titio OpenFOAM 2 June 9, 2010 11:45
