[snappyHexMesh] surface feature extract fatal error
Old   July 21, 2020, 17:32
Default surface feature extract fatal error
Typ
Typ is on a distinguished road
iam getting an fatal error when i try to run surface feature extract:
Note: Feature line extraction only valid on closed manifold surfaces
Reading surfaceFeatureExtractDict
Surfaces     : a.stl
Output       : a
Load options : offset
Write options: writeObj=no writeVTK=off
--> FOAM FATAL ERROR:
Problem loading surface(s) for entry: a.stl
Do someone maybe know what typical cause this error?
Typ is offline   Reply With Quote
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
