[snappyHexMesh] SHM not snapping my geometry
Old   July 21, 2020, 06:39
Post SHM not snapping my geometry
Anand
ananddoss2004 is on a distinguished road
Hi all,
I have created a simple geometry and i want to mesh it. I kept the stl file in trisurface folder and changed the block mesh dict, surface feature extract and snappy hex mesh dict accordingly. After running in Openfoam, all i get to see is the block mesh domain and no geometry inside. I am very new to OpenFoam and someone please help me with the files attached.
Since 5 files is maximum limit, i have attached the remaining two in the next thread. Dict files contain the block, surface feature and snappy hex files. Room file contains the stl that i have divided into 5 sub parts with three in this post and two in the following thread. Downloading all will give the complete stl file that you can look into.
Looking forward for a quick response from interested people.
ananddoss2004 is offline   Reply With Quote
Old   July 21, 2020, 06:41
Post Remaining two files attached
Anand
This is continuation to the previous thread where i have attached the remaining file to complete the geometric file. Please find the attached file here.
shm not snapping
[snappyHexMesh] gaps for close surfaces- meshing with sHM jango OpenFOAM Meshing & Mesh Conversion 0 November 28, 2016 03:10
[snappyHexMesh] different sHM results on same geometry when everythin is in one or several stl-files. Laika OpenFOAM Meshing & Mesh Conversion 1 September 8, 2016 05:09
[snappyHexMesh] SHM: feature edge snapping not conforming thab OpenFOAM Meshing & Mesh Conversion 3 November 26, 2012 15:04
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
[snappyHexMesh] sHM with cyclic patch on stl geometry johannesk OpenFOAM Meshing & Mesh Conversion 2 August 21, 2009 10:08
