[blockMesh] refine mesh with stl region
Old   July 17, 2020, 00:27
Default refine mesh with stl region
Francisco T
frantov is on a distinguished road
Hi Foamers
Apologies if this was asked before.
Is it possible to refine a region of a mesh created by BlockMesh using an STL file?
The region is defined by an STL and is not part of the geometry (is not a boundary), but is defined initial alpha.water distribution.
What I do is the following:
1. Generate a mesh with blockMesh
2. Set fields (setFieldsDict) with the STL
3. Refine mesh with dynamicMesh dict, but some information is lost as blockMesh is coarse.
I have tried snappyHexMesh, but so far in my attempts, it treats the STL as boundary, and snappy is an overkill as this is a simple geometry.
any clues will be appreciated!
thanks
Fran
frantov is offline   Reply With Quote
Old   July 17, 2020, 01:06
Francisco T
I found a get around from another post (thanks to OlivierG):
Generating Mesh for a drop in another fluid
1) from you initial mesh, use setFields
2) run 1 iterate with interDyMFoam => this with refine mesh at interface
3) call setField again (re initialise)
4) run ...
blockmesh, stl
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Error when solving p_rgh bob94 OpenFOAM 0 March 17, 2020 09:12
[snappyHexMesh] Not Able to Refine Mesh in Refinement Box noodleluvmay OpenFOAM Meshing & Mesh Conversion 2 January 27, 2020 11:55
[Other] conformed FSI mesh for unstructured fluid region ashish.svm OpenFOAM Meshing & Mesh Conversion 10 August 2, 2019 09:40
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
