July 15, 2020, 10:33 |
Errors mergeMeshes
Jacques Durand
Rep Power: 6 |
I have a problem with my final mesh when I use mergeMeshes. I work on a vertical axis wind turbine and I want to compute the aerodynamic forces on it. I created two meshes with ANSYS Meshing : the first one is a cylinder around the wind turbine (rotating part) and the second one is the fluid domain (static part). I converted the mesh in the correct format (with fluent3DMeshToFoam) and after, the checkMesh in OpenFOAM with these two meshes is OK. I use mergeMeshes stator rotor to assembly these two meshes. I have this error with checkMesh Code:
Checking geometry... Overall domain bounding box (-100 -100 -25) (100 300 175) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.21064e-16 5.45597e-17 -2.88435e-16) OK. ***Open cells found, max cell openness: 1, number of open cells 140 <<Writing 140 non closed cells to set nonClosedCells <<Writing 259901 cells with high aspect ratio to set highAspectRatioCells ***Zero or negative face area detected. Minimum area: 0 <<Writing 153433 zero area faces to set zeroAreaFaces ***Zero or negative cell volume detected. Minimum negative volume: -1.2717e-06, Number of negative volume cells: 109846 <<Writing 109846 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 180 average: 35.956 *Number of severely non-orthogonal (> 70 degrees) faces: 3767400. ***Number of non-orthogonality errors: 361034. <<Writing 4128434 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 90190 faces are incorrectly oriented. <<Writing 85101 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 3.55271e+135, 41541 highly skew faces detected which may impair the quality of the results <<Writing 41541 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 6 mesh checks. The refined mesh is made with "Inflation" in ANSYS Meshing. checkMesh for the non-refined mesh : Code:
Checking geometry... Overall domain bounding box (-100 -100 -25) (100 300 175) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.0156e-16 6.08894e-17 -2.87194e-16) OK. Max cell openness = 2.74847e-16 OK. Max aspect ratio = 23.0191 OK. Minimum face area = 0.000372473. Maximum face area = 158.928. Face area magnitudes OK. Min volume = 3.42439e-06. Max volume = 643.763. Total volume = 1.59985e+07. Cell volumes OK. Mesh non-orthogonality Max: 82.8572 average: 16.2069 *Number of severely non-orthogonal (> 70 degrees) faces: 97. Non-orthogonality check OK. <<Writing 97 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 1.82115 OK. Coupled point location match (average 0) OK. Mesh OK. Thank you for your answers ! |
December 21, 2022, 16:22 |
Lucas Cytrangulo
Any updates on this thread?
mesh, mesh conversion |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
