Alice Zanella
Rep Power: 6 ![]() |
Hello there!
I'm currently doing a simulation of a tall building and I have a few doubts, I hope someone can answer them.
Alice |
Lisandro Maders
Rep Power: 13 ![]() |
1. I didn't get exactly what you meant.. do you want or do you NOT want to have different boundary layers for each of them? I would recommend that you have same number of layers if both patches are connected, while it is fine to have different sizes and grow rates for them. 2. Use the CFD-Online calculator for that (https://www.cfd-online.com/Tools/yplus.php) You have to specify the desired y+ value, which depends on the turbulence model and wall function approach used. There are several posts discussing this (a quick search will tell you which y+ size you should use). 3. One thing has nothing related to another. Using the ABL gives you a better inlet profile,but you still need to resolve the boundary layer on every no-slip wall you have in the domain. Cheers! |
abl, boundary layer, building aerodynamics, turbine siting |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Any formula for approximating the boundary layer thickness around a cylinder? | bestniaz | Main CFD Forum | 0 | October 24, 2015 02:00 |
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues | nathanricks | ANSYS Meshing & Geometry | 0 | September 23, 2015 05:14 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
