[Gmsh] Gmsh trouble converting to openFOAM?
Old   June 9, 2020, 21:54
Default Gmsh trouble converting to openFOAM?
NotApplicable
skodali is on a distinguished road
I have had a lot of trouble with gmsh recently. I believe I finally got a unstructured volume mesh, however.
So anyway, I finally generated a volume mesh with an internal 'hole volume' (boundary), and I exported the .msh file, and if I choose version 4 ASCII I get an error that it cannot convert "higher-order" meshes. I don't know how to generate lower order meshes in gmsh... or that it was even generating higher-order meshes.
I try exporting Version 1, and it successfully converts, but everything is 1 zone, 0, where does it find the zone information?? Does anyone know how to remedy this? https://i.imgur.com/sHpGeLF.png
Any help would be really appreciated.
EDIT:
Solved! The problem was that in addition to making a volume elementary entity before generating the volume mesh, I also had to add a volume physical group before exporting it. Then, I exported it using version 2, and unchecked the all elements box.
skodali is offline   Reply With Quote
Old   June 10, 2020, 19:51
Etienne Lorriaux
elorriaux is on a distinguished road
Hello, try using gmsh version 2 format, in ascii.
elorriaux is offline   Reply With Quote
gmsh, mesh, mesh 3d
[Gmsh] Issue converting mesh from gmsh to openFoam victorbelenense OpenFOAM Meshing & Mesh Conversion 9 February 20, 2019 06:17
Can't convert my mesh created in Gmsh to OpenFOAM Crystal 95 OpenFOAM 1 May 2, 2018 11:42
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Trouble with sampleDict syntax for OpenFOAM 2.3.1 rawdoggity OpenFOAM Post-Processing 1 February 1, 2015 06:24
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
