[snappyHexMesh] mesh snapping at edge of patches created from .stl files
Old   June 1, 2020, 10:23
Default mesh snapping at edge of patches created from .stl files
Alexandra H
simply-alex is on a distinguished road
Hello all, I hope you are well!
Backround:
  • I am trying to simulate flow around a static aerofoil cascade (aka turning vanes) to direct flow around a 90deg corner.
  • I am trying to reduce the yPlus value below 1 on the entire surface, while at the same time reducing computational requirements.
  • To achieve this, I have split each aerofoil into 7 patches generated from stl files. The stl files are exported from solidworks and are waterproof (no overlap, no gaps).
Problem:
  • During the snapping stage, the cells that are close to a patch edge snap correctly, but create a very small boundary face (see pictures).
  • During the addLayers stage, this small face is extruding, leading to thin cells and a high Courant Number.
  • Using a minArea limit is not possible, as the smallest problem cell is in refinement level 6 and the largest problem cell is in level 2. As such, their size magnitudes are different and cannot be captured by a minArea limit.
  • The new "mergeAcrossPatches" option does not seem to solve this problem (it also does not seem to work well when I try to add layers).
I have spent a long time trying to fix this, so any suggestions would be more than welcome! Thanks in advance and regards,
Alex
simply-alex is offline   Reply With Quote
edge, patch, snapping, stl
[mesh manipulation] Multi-region mesh from .stl files in OpenFoam V7 carl_r OpenFOAM Meshing & Mesh Conversion 11 December 11, 2024 09:06
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
