[blockMesh] Wedge patch 'asym1' is not planar
Old   June 1, 2020, 05:25
Default Wedge patch 'asym1' is not planar
shouvik ghorui
shouvik ghorui is on a distinguished road
Hello, everyone, I am new in OpenFOAM.actually I am trying to simulate CD NOZZLE in OpenFOAM for that I am trying to do the wedge shape cd nozzle in blockMesh but when I execute blockMesh command then I get some warning "From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBu ffers&)
in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 70
Wedge patch 'asym1' is not planar.
At local face at (2.89971 0.458605 0.0181999) the normal (-0.00263556 -0.0396659 0.99921) differs from the average normal (-0.000358542 -0.041792 0.999109) by 9.71493e-06
Either correct the patch or split it into planar parts" and in the checkMesh command i am geting one fail "***Wedge patch asym2 not planar. Point (0.0894127 0.890887 -0.028) is not in patch plane by 1.70649e-05 metre." i attach my blockMeshDict
my question is how I will resolve the warning.
if any data is required then, please let me know. thanks in advance. if anyone helps me it will be great for me.
File Type: zip blockMeshDict.zip (970 Bytes, 3 views)
shouvik ghorui is offline   Reply With Quote
blockmesh, wedge mesh axisymmetric, wedges
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 7 September 18, 2024 06:52
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 05:48
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
