[Other] Refining predefined mesh for injection
Old   May 19, 2020, 11:51
Default Refining predefined mesh for injection
Josep
crausin is on a distinguished road
Hi! I'm doing somme researchwork on injection. My case is that i have a predefined mesh for the type of geometry I'm suposed to study. From that basic case I'm doing some variations on parameters of the geometry such as the inclination of the orifice (which is the one that i'm having problems with).
The problem is that I want a quick solution for refining or rotating parts of my internal mesh in order to adapt the mesh to the deviation of the jet when the orifice is inclined. I attach an image of a case i solved and diverged due to porr mesh refinement near to the jet so see the problem I have.
I don't want to increase a lot the computatinal cost.
crausin is offline   Reply With Quote
injections, open foam, refine mesh
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
