[mesh manipulation] polyDualMesh, how to preserve cellZones in a multi-regions mesh? |
Neilson Whit
Rep Power: 15 ![]() |
Dear Foamers
I want to do a conjugate heat transfer simulation with chtMultiRegionFoam. As you know, I have several solid regions designated with different cellZones which were created in SALOME. I want to convert fluid zone meshes "only" to polyhedral meshes while keeping other regions same as tetrahedral. But does not matter if convert other regions too. When I do this with polyDualMesh, it converts successfully but cellZones disappears. You may propose to use topoSet by using STL geometry files to re-define the zones on the new polyhedral mesh, I tied already, but some tiny region meshes cannot be captured... is there any way of achieving this while preserving the zones with polyDualMesh ? thank you |
cellzones, chtmultiregionfoam, polydualmesh |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] Propeller mesh not smooth | nortanapura | OpenFOAM Meshing & Mesh Conversion | 0 | May 16, 2014 03:26 |
[mesh manipulation] polyDualMesh, create a tetrahedral mesh from a polyhedral mesh | Martin80 | OpenFOAM Meshing & Mesh Conversion | 5 | January 30, 2013 22:07 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
