[Gmsh] structured mesh in Gmsh appears triangular after gmshtofoam
Old   April 24, 2020, 12:39
Default structured mesh in Gmsh appears triangular after gmshtofoam
Liam
lg331 is on a distinguished road
I created a 3D structured mesh in gmsh, which was created well, without error or warning. However when I transferred it to openFOAM format using gmshtofoam, and then viewed it in paraview, it appeared differently to the gmsh. Any help will be very much appreciated? Is it something to do with paraview?
I'm new to gmsh and openFOAM and I'm using mac. The attached are the figures, which show a region of the domain.
lg331 is offline   Reply With Quote
Old   April 27, 2020, 02:25
Andreas P.
AndreasPe is on a distinguished road
There is an option in paraview called "triangulate the slice". Just disable this option and your mesh should look hexahedral again.
AndreasPe is offline   Reply With Quote
Old   April 27, 2020, 07:56
Liam
Many thanks Andereas. It solves the problem.
Now I'm trying to densify my mesh. But gmshtofoam process killed without any error message; please see the attached. Any idea why?
Old   April 27, 2020, 08:04
Andreas P.
I've never worked with gmsh / gmshToFoam.
Maybe have a look at your RAM usage?
Old   April 27, 2020, 08:07
Liam
OK thank you very much again. I'll have a look.
gmsh, structured mesh
[Gmsh] GMSH: Structured mesh of a square inside a circle wc3speler OpenFOAM Meshing & Mesh Conversion 3 September 18, 2019 17:13
[ANSYS Meshing] Structured Mesh inside an egg-like geometry BrunoCFD ANSYS Meshing & Geometry 1 October 31, 2018 15:48
[ICEM] Unstructured Tetra Mesh around Structured Hexa Mesh grinser92 ANSYS Meshing & Geometry 0 April 12, 2017 16:05
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
