[blockMesh] BlockMesh: simpleGrading is not working with x>1 in z-Direction
Old   April 24, 2020, 11:30
Default BlockMesh: simpleGrading is not working with x>1 in z-Direction
Daniel
Dmarcohe is on a distinguished road
Hello Everyone,
i am trying to mesh a simple geometry with blockMesh. Now i want to refine some regions with simpleGrading, but it only works with 1 in z-Direction. I put everywhere the same number of cells but (15 1 x>1) etc. is not working.
--> FOAM FATAL ERROR:
Inconsistent point locations between block pair 1 and 2
probably due to inconsistent grading.
(2 in z-Direction for hex I - V)
When i am putting in first the z-Lines there is no Problem, but then blockMesh will not grade the mesh.
CheckMesh only failed the check about the aspectRatios which should be irrelevant.
Here is my blockMesh dict
vertices
(0 0 0) //0 Block
(1.2 0 0) //1
(1.9 0 0) //2
(2.1 0 0) //3
(2.8 0 0) //4
(4 0 0) //5
(4 0.5 0) //6
(2.8 0.5 0) //7
(2.1 0.5 0) //8
(1.9 0.5 0) //9
(1.2 0.5 0) //10
(0 0.5 0) //11
(0 0 1) //12
(1.2 0 1) //13
(1.9 0 1) //14
(2.1 0 1) //15
(2.8 0 1) //16
(4 0 1) //17
(4 0.5 1) //18
(2.8 0.5 1) //19
(2.1 0.5 1) //20
(1.9 0.5 1) //21
(1.2 0.5 1) //22
(0 0.5 1) //23
(0 0 3) //24
(1.2 0 3) //25
(1.9 0 3) //26
(2.1 0 3) //27
(2.8 0 3) //28
(4 0 3) //29
(4 0.5 3) //30
(2.8 0.5 3) //31
(2.1 0.5 3) //32
(1.9 0.5 3) //33
(1.2 0.5 3) //34
(0 0.5 3) //35
(1.7 0 -5) //36 Düse
(2.3 0 -5) //37
(2.3 0.5 -5) //38
(1.7 0.5 -5) //39
blocks
hex (0 1 10 11 12 13 22 23) (15 1 1) simpleGrading (1 1 1) //I Block
hex (1 2 9 10 13 14 21 22) (25 1 1) simpleGrading (1 1 1) //II
hex (2 3 8 9 14 15 20 21) (75 1 1) //III
simpleGrading
(0.5 0.5 4) // 50% y-dir, 50% cells, expansion = 4
(0.5 0.5 0.25) // 50% y-dir, 50% cells, expansion = 0.25
2 //Y-Richtung
3 //Z-Richtung
hex (3 4 7 8 15 16 19 20) (25 1 1) simpleGrading (1 1 1) //IV
hex (4 5 6 7 16 17 18 19) (15 1 1) simpleGrading (1 1 1) //V
hex (12 13 22 23 24 25 34 35) (15 1 1) simpleGrading (1 1 1) //VI
hex (13 14 21 22 25 26 33 34) (25 1 1) simpleGrading (1 1 1) //VII
hex (14 15 20 21 26 27 32 33) (75 1 1) //VIII
simpleGrading
2 //Y-Richtung
3 //Z-Richtung
hex (15 16 19 20 27 28 31 32) (25 1 1) simpleGrading (1 1 1) //IX
hex (16 17 18 19 28 29 30 31) (15 1 1) simpleGrading (1 1 1) //X
hex (36 37 38 39 2 3 8 9) (75 1 200) //XI Düse
simpleGrading
2 //Y-Richtung
3 //Z-Richtung
edges
boundary
fixedWalls
type wall;
faces
(0 11 23 12) //Seite links
(12 23 35 24)
(5 6 18 17) //Seite rechts
(17 18 30 29)
(0 1 10 11) //Boden
(1 2 9 10)
(3 4 7 8)
(4 5 6 7)
(24 25 34 35) //Decke
(25 26 33 34)
(26 27 32 33)
(27 28 31 32)
(28 29 30 31)
(36 39 9 2) //Düse links
(37 38 8 3) //Düse rechts
(36 37 38 39) //Düse Unten
frontAndBack
type empty;
faces
(0 1 13 12) //Vorne unten
(1 2 14 13)
(2 3 15 14)
(3 4 16 15)
(4 5 17 16)
(12 13 25 24) //Vorne oben
(13 14 26 25)
(14 15 27 26)
(15 16 28 27)
(16 17 29 28)
(11 10 22 23) //Hinten unten
(10 9 21 22)
(9 8 20 21)
(8 7 19 20)
(7 6 18 19)
(23 22 34 35) //Hinten oben
(22 21 33 34)
(21 20 32 33)
(20 19 31 32)
(19 18 30 31)
(36 37 3 2) // Düse vorne
(39 38 8 9) // Düse hinten
Dmarcohe is offline   Reply With Quote
blockmeshdict, meshing 2d, openfoam 1806, refinement
[blockMesh] error with internal face or belongs to other patch cfd1609496 OpenFOAM Meshing & Mesh Conversion 2 July 10, 2019 11:36
pimpleDyMFoam - rho not found maasyraf3 OpenFOAM Running, Solving & CFD 10 June 5, 2017 14:05
[blockMesh] FOAM FATAL ERROR: face 0 in patch 0 does not have neighbour cell face am9109 OpenFOAM Meshing & Mesh Conversion 41 October 15, 2015 04:59
[blockMesh] refinement of mesh around a half-cylinder-using blockMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 6 July 17, 2013 07:11
[blockMesh] Error in BlockMesh: inconsistent number of faces pc1 OpenFOAM Meshing & Mesh Conversion 7 August 20, 2010 07:24
