[Salome] How can I read and treat .stl files of Salome?
Old   April 23, 2020, 13:51
Default How can I read and treat .stl files of Salome?
david
falencio is on a distinguished road
When I try to convert my .stl files of Salome to .obj files, I have this error
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
Build : 7-1ff648926f77
Exec : surfaceConvert -clean Inlet1.stl Inlet1.obj
Date : Apr 23 2020
Time : 18:45:55
Host : "francisc-VirtualBox"
PID : 4913
I/O : uncollated
Case : /home/franciscoboira/pipe
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Reading : "Inlet1.stl"
--> FOAM FATAL ERROR:
Cannot read "Inlet1.stl"
From function bool Foam::triSurface::read(const Foam::fileName&, const Foam::word&, bool)
in file triSurface/triSurface.C at line 304.
FOAM exiting
I don't know why. I cannot combine this kind of files neither, with
$ surfaceAdd Inlet1.obj Inlet2.stl pipe.stl
The same error its appeared.
However, if I do paraview, I can see the geometry, but I need to do the above actions but I have the error.
Thanks for your patience
falencio is offline   Reply With Quote
Old   April 24, 2020, 04:24
Siassei is on a distinguished road
I'm putting the stl files in the constant directory and an geometry entry like
    mesh1
        name "mesh1";
        type triSurfaceMesh;
        file "./constant/mesh.stl";
        regions
            Inlet_1                // Named region in the STL file
                name Inlet1;       // User-defined patch name
            }                      // otherwise given mesh.stl_Inlet_1
Siassei is offline   Reply With Quote
salome, snappy hex mesh
