[snappyHexMesh] Little Help with SnappyHexMesh for Beginners
Old   April 23, 2020, 06:47
Default Little Help with SnappyHexMesh for Beginners
SimonStar's Avatar
Simon
SimonStar is on a distinguished road
Hello guys!
I'm trying to make a mesh with SnappyHexMesh.
I did several tutorials now and gererally I like it.
But there are two things i really worry about:
- Prismatic layers are collapsing from time to time
- My mesh is out of (often very sharp) triangles and not out of squares like in the tutorials.
To compare I got two pics for you: First my mesh and secondly a mesh from a tutorial (similar settings other geometry).
So waht can I do to make my mesh better?
Is the second issue maybe just becuase I have a false view and the mesh at itself is the same?
I world be very good to have it so nice than in the tutorial.
Thanks a lot
I'm happy about all help!
SimonStar is offline   Reply With Quote
Old   April 23, 2020, 07:50
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Simon,
Your second issue is just related to visualization in paraView :
  1. When you create a slice in ParaView, uncheck "triangulate slice" to get rid of the triangles
  2. If you want the same visualization than in the picture you have posted, check the "crinkle slice" option
About your first question : having a good prism layers coverage on your geometry can be a tricky thing to achieve with snappy. It takes some time to fiddle with the addLayersControls and meshQualityControls parameters.
Cheers,
Yann
Yann is offline   Reply With Quote
Old   April 23, 2020, 08:53
SimonStar's Avatar
Simon
Hello, Yann!
Thank you for the very good information, it was herping me a lot.
So do I see it right that the slice with unchecked triangulation and wich checked 'Crinkle Mesh' is showing the real 3D-mesh - and only with checked triangulation its showing the 'normal CAD-surface-triangles'?
And are the prism layers better with another program?
Thank you
mesh, openfaom-7, prismatic, snappyhexmesh
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 17:02
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
