[Other] Error: topoSet – create patch from .stl – searchableSurfaceToFaceZone |
Carl Reilly
Rep Power: 16 ![]() |
Hi, I’m relatively new to OF and am using OF foundation V7. I have am trying to create a multi-region mesh for a chtMultiRegionFoam model. I have:
When I run topoSet I get the following error: Code:
Reading topoSetDict Time = 0 mesh not changed. Created faceZoneSet SD_CC Applying source searchableSurfaceToFaceZone --> FOAM FATAL ERROR: Cannot find triSurfaceMesh starting from "/home/carl/OpenFOAM/carl-7/run/LPDCtest/geomTest1/constant/triSurface/geomTest1" From function static Foam::fileName Foam::triSurfaceMesh::checkFile(const Foam::regIOobject&, const Foam::dictionary&, bool) in file searchableSurfaces/triSurfaceMesh/triSurfaceMesh.C at line 124. FOAM exiting The contents of topoSet file are: Code:
actions ( // Select patch based on surface defined by .stl file. Orientation from normals on surface { name SD_CC; type faceZoneSet; action new; source searchableSurfaceToFaceZone; sourceInfo { surface triSurfaceMesh // name "SD_CC.stl"; name "/home/carl/OpenFOAM/carl-7/run/LPDCtest/geomTest1/constant/triSurface/SD_CC.stl"; } } ); I've tried defining the name variable as the full path, file name only, in quotations, out of quotations. The .stl is accessible. Looking at the error I see that it is looking for a triSurfaceMesh, not a file, and it is "starting" from a directory that does not exist. I'm not sure why the model directory (geomTest1) is specified as the final directory (is this a bug?). I am also not certain that my methodology is correct. Imagine I have 2 cubes with face to face contact, defined by .stl files. I previously made a simple model with heat transfer on the patch between the two cubes. In this model I want to have the same heat transfer between the two, but also a heat source on a patch on a face of cube1. This patch is irregular shaped and so needs to be formed by and .stl file not another tool available in topoSet or setSet. This is a training exercise for me, my final geometry will be more complex, hence forming the cubes with stl files too. Currently I mesh the cubes using sHM, then in topoSet specify the stl of the region for the heat source. Cube 1 has the edges for the region within the geometry so that the feature is captured in the sHM meshing. Is this correct or do I somehow need to define the region in the sHM process? Any help would be appreciated |
Shuji Chang
Rep Power: 4 ![]() |
try <name SD_CC.stl>
no quotation marks and path |
stl, toposet |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
