[blockMesh] Meshing a "triangle" with blockMesh
Old   April 2, 2020, 13:04
Default Meshing a "triangle" with blockMesh
Marc Batlle
Marc Batlle is on a distinguished road
Good afternoon Foamers,
These days I am facing problems to mesh a triangular shape together with rectangle the way I want. I think the best explanation comes with a representative sketch.
I attach two images, the "OP_1" is what I am looking for, and, the "OP_2" what I obtain.
I already tried to mergePatchPair unsuccesfully, wondered about splitMesh but dismissed due to a lack of information ..
Any help is welcomed
Marc Batlle is offline   Reply With Quote
Old   April 2, 2020, 17:48
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Any blockMeshDict, which doesn't work? Working over it might help.
HPE is offline   Reply With Quote
Old   April 3, 2020, 03:53
Bram Kerkhofs1
brammekeuh987 is on a distinguished road
Hi Marc
I would make two meshes: A rectangle (block1) and a parallelogram (block2). Then try to cut the parallelogram in 2, in order to get the triangle.
Cutting the mesh up, you can use splitMesh. To figure out how it works, type splitMesh -help in your terminal.
There you see something like this :
Usage: splitMesh [OPTIONS] <faceSet> <master> <slave>
Arguments:
<faceSet>         The faces used for splitting
<master>          The master patch name
<slave>           The slave patch name
Options:
-case <dir>       Specify case directory to use (instead of the cwd)
-overwrite        Overwrite existing mesh/results files
-doc              Display documentation in browser
-help             Display short help and exit
-help-compat      Display compatibility options and exit
-help-full        Display full help and exit        Splits mesh by making internal faces external at defined faceSet
At the top it says how to use it, completely on the bottom it says what it does. As you see, you need to get a faceSet.
You can use setSet for this, or topoSet. setSet does the same as topoSet, but if you google the topoSet wiki, it has a more complete explanation regarding the possibilities.
In order to define the domain, you can use a searchableBox, and make it of the dimensions so all the cells of the triangle are in there, and than filter the right faces out. I would do something like this:
cellSet of all cells in the triangle
cellSet inverted version of above cells (to invert it, you first need to copy it, and than invert it)
faceSet of the first cellSet
faceSet of the second cellSet
faceSet subset of first cellSet with second cellSet
So cut the mesh, and than use stitchMesh to stitch it.
Hope this helps!
brammekeuh987 is offline   Reply With Quote
Old   April 3, 2020, 05:52
Franco Marra
francescomarra is on a distinguished road
Dear Marc,
a possible solution could be to split the triangle (that is the real problem) into three subfigures as in the attached picture.
Best regards,
Franco
francescomarra is offline   Reply With Quote
Old   April 3, 2020, 11:40
Marc Batlle
Hello again and thanks for your replies,
I have been working on Bram's answer without success for the moment.
As requested, I attach a simple case only meshing the "triangle" which initially I define as a parallelogram with only 4 cells for simplicity. A topoSetDict file can also be found in /system with my interpretation from Bram's suggestions.
Thanks again.
Old   May 13, 2022, 14:31
M. Constanza Sadino Riquelme
sadinori is on a distinguished road
Hello Marc,
I want to create a similar mesh. Could you find a strategy for this?
Thank you
sadinori is offline   Reply With Quote
Old   November 25, 2022, 14:08
Gerardo Zegers
Gzegers is on a distinguished road
I was having the same issue and solved the problem using francescomarra solution! Here is my blockmesdict.
Best,
Gerardo
/*--------------------------------*- C++ -*----------------------------------*\n| ========= | |
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 2.3.1 |
| \ / A nd | Web: www.OpenFOAM.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0.143424 0.143292 -6.949927463502417)//0
(1.000188 0.143292 -6.949927463502417)//1
(1.000188 1.856396 -6.949927463502417)//2
(0.143424 1.856396 -6.949927463502417)//3
(0.143424 0.143292 -6.589941731751209)//4
(0.7145999999999999 0.143292 -6.709936975668278)//5
(0.7145999999999999 1.856396 -6.709936975668278)//6
(0.143424 1.856396 -6.589941731751209)//7
(0.143424 0.143292 -6.229956)//8
(1.000188 0.143292 -6.589941731751208)//9
(1.000188 1.856396 -6.589941731751208)//10
(0.143424 1.856396 -6.229956)//11
(1.856952 0.143292 -6.949927463502417)//12
(1.856952 1.856396 -6.949927463502417)//13
blocks
hex ( 3 2 6 7 0 1 5 4) fluido (8 8 3)
simpleGrading (1 1 1 )
hex (7 6 10 11 4 5 9 8) fluido (8 8 3)
hex (2 13 10 6 1 12 9 5) fluido (8 8 3)
edges
boundary
mergePatchPairs
File Type: jpg Screenshot from 2022-11-25 11-05-39.jpg (59.2 KB, 60 views)
Gzegers is offline   Reply With Quote
blockmesh, mergepatchpair, splitmesh, triangle
[ANSYS Meshing] Cooper Method Meshing RTN3000 ANSYS Meshing & Geometry 1 March 2, 2015 00:59
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 15:27
[blockMesh] error Meshing a 3D cube geometry with blockMesh GodOfLove OpenFOAM Meshing & Mesh Conversion 5 July 14, 2009 16:30
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
