[snappyHexMesh] Placing an object on top of the NACA0012 airfoil shape |
Najmiddin
Rep Power: 7 ![]() |
Hello folks,
I am trying to snap an object on top of the airfoil shape. The mesh was not created using blockMesh, instead I used the following codes to create my meshes: Code:
plot3dToFoam -2D 0.1 -noBlank -noFunctionObjects n0012_113-33.p2dfmt autoPatch 30 -overwrite createPatch -overwrite extrudeMesh Code:
slurmstepd: error: Step 2361478.4294967294 hit memory limit at least once during execution. This may or may not result in some failure. Code:
castellatedMesh true; snap true; addLayers false; geometry { VorGen.stl { type triSurfaceMesh; name VorGen; tolerance 2; } }; castellatedMeshControls { maxLocalCells 300000; maxGlobalCells 50000000; minRefinementCells 0; maxLoadUnbalance 0.10; nCellsBetweenLevels 3; features ( { file "VorGen.eMesh"; level 5; } ); refinementSurfaces { VorGen { level (5 5); patchInfo { type wall; } } } resolveFeatureAngle 30; refinementRegions { } locationInMesh (0.095 0.05 -0.05); allowFreeStandingZoneFaces true; } snapControls { nSmoothPatch 3; tolerance 2.0; nSolveIter 300; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap true; explicitFeatureSnap false; multiRegionFeatureSnap false; } naca1.jpg naca2.jpg Thanks in advance! |
airfoil 2d, naca 0012, snappy hex mesh |
Most experimentally stuided airfoil, wing, shape collection! | northfly | Main CFD Forum | 0 | October 21, 2018 21:47 |
NACA0012 Validation Accuracy Improvement | Alhasan | OpenFOAM Running, Solving & CFD | 8 | February 1, 2015 08:39 |
Why is air pressure lower on the top of an airfoil ? | omaraero | Lounge | 11 | September 1, 2014 00:45 |
[Other] Generating Mesh - NACA0012 Airfoil | baila12 | OpenFOAM Meshing & Mesh Conversion | 3 | July 25, 2013 06:57 |
Simulation of transonic flow over NACA0012 airfoil | MSc Student | Siemens | 2 | August 9, 2006 13:49 |
